Thread started 14 Mar 2006 (Tuesday) 00:59
lens filters for powershot pro
lisamgunderson
Mar 14, 2006 00:59 |  #1
Does anyone sell filters for the Powershot cameras? I have a Powershot Pro camera and the lens cap keeps coming off. One day I know that I will lose it and the lens will get damaged. Does anyone else have this problem with this camera?
Lisa
gardenstate
Mar 14, 2006 06:51 |  #2
I have a G6 at home and use a Powershot Pro 1 at work. FOR EXTRA LENS PROTECTION -- use the Canon provided adapter ring and then screw in a 58mm UV or skylight filter over your existing lens.
Some watchouts -- you have a high quality Canon lens -- use a high quality filter for the best image quality-- I have a 58mm multicoated HOYA UV filter. Keep the Pro 1 in a protective case when not in use.
also -- in my case, the Pro1 lens cap snaps into place and is quite secure -- perhaps you need a new cap..
david814
Mar 14, 2006 13:04 as a reply to  @ gardenstate's post |  #3
Filters are available but be careful with the lens adaptor, very, very fine threads and easy to cross thread, best advice put the filter on and let it stay. The big nuisance with the Pro-1 is the fact that the lens cover is sooo easy to lose bcause it isn't attached. Anybody found a nice clean way to attach to body?
David
SonyaL
Mar 14, 2006 20:35 as a reply to  @ david814's post |  #4
I found the filters for the pro 1 at Best Buy. I bought the UV filter and the Polarizing filter there.
I try to be careful with the adapter ring I have read so much about people have issues of not being able to get it off or it cross threading.
I need to order some spare ones just in case.
Sonya
lisamgunderson
Mar 14, 2006 20:47 |  #5
Very good information, thank you all for your help!
Lisa
zacker
Joined Jan 2005
Mar 14, 2006 21:07 |  #6
go to your local camera store and look for the cap keeper, its a small round piece of plastic that is attached to a rubber ring by a thread, you use double sided tape or glue to stick it on your cap, then you attack the rubber end to your neck strap so when you take off the cap, it sorta just hangs there. I had one but didnt like it... and yes, the pro1 lets dust inside verywillingly so when its not in use, keep it in its case or camera bag. you can get extra filter adapters from canon.. youll want one to be able to change the filters, once they are on the adapters, they are a bull to get off again.
-zacker-
http://www.theanimalha​ven.com (external link)
My Facebook, Friend me If you want!http://www.facebook.co​m/brokenfencephotograp​hy (external link)
http://www.facebook.co​m/theanimalhaven?ref=t​s (external link)
Wsman2
Gallery: 6 photos
Mar 15, 2006 00:29 |  #7
I bought Quantaray UV, Circular Polarizer, and Neutral Density 2 filters through Wolf/Ritz Camera. They have a deal of buy 2, get 1 free. If you go for that, be aware that the "free" filter will not be the most expensive of the 3 you pick.
I also bought a Tamrac filter wallet since I bought extra filter adapters for those filters to keep them attached. There's a little more room in the wallet and I'll have my filters in one place.
Wolf Camera (external link)
Ritz Camera (external link)
Wil
Click to see Wil's Flickr Photoset (external link)
lisamgunderson
Mar 15, 2006 18:52 |  #8
Where can we order the filter adapter ring? I have checked the canon website, bh photo, ritz camera, even tried Best Buy, I cant seem to locate them. does anyone know where to find these?
Thanks for your help
Lisa
zacker
Joined Jan 2005
Mar 15, 2006 19:33 |  #9
you need to get the part number from your manual then call canon because its not an actual replacement part, that is why it isnt listed on the site.
-zacker-
Hank2122
Joined Feb 2006
Mar 15, 2006 20:53 |  #10
For the lens adpater, you can even try Ebay. I think I've come across them before. One thing I found helpful was one of these:
http://www.jr.com …rabber.datafeed​.OPT+07551 (external link)
it goes between the filter and the adapter ring. 58mm right? I know it looks weird, but very useful and you won't lose your cap (unless you lose the camera).
it does cause some shadows with the internal flash though.
5D/Canon 17-40mm f4L/Canon 24-105mm f4L/Canon 50mm f1.8/Canon 85mm f1.8/Sigma 150mm f2.8/Canon 70-200mm f2.8L IS/580ex/580ex
glowluzid
Joined Feb 2006
Mar 16, 2006 12:08 as a reply to  @ lisamgunderson's post |  #11
Call canon parts, 732-521-7230, ask for the FA-DC58A filter adapter. It runs $6 plus change, and shipping is about $6. Not cheap, but the only source I know of.
http://www.surrealcolo​r.com (external link)
http://www.surrealmode​ls.com (external link)
Color and B&W Infrared work
Canon 20d, pro1-IR, G3-IR
zacker
Joined Jan 2005
Mar 16, 2006 12:20 |  #12
is that the right Part Number? why does it look like the Tele-adapter tube? But then I could be wrong..anyhow, that is exactly how i got mine. I wish I has the part number still.
-zacker-
Wsman2
Gallery: 6 photos
Mar 16, 2006 15:05 |  #13
I don't have my camera with me, but according to Canon's U.S. site for PowerShots, the filter adapter # for the Pro 1 is FA-DC58A.
Wil
lisamgunderson
Mar 16, 2006 16:04 |  #14
Thanks for your help, I will try calling Canon for the part.
Lisa
5,115 views & 0 likes for this thread, 8 members have posted to it.
2180 guests, 129 members online
