Has anyone used one to offer a mini review?
https://youtu.be/kjP93YJFzgw![]()
Gungnir Senior Member More info | Jan 15, 2017 10:40 | #1 Has anyone used one to offer a mini review? Steve
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info | Jan 15, 2017 11:49 | #2 Gungnir wrote in post #18245049 Has anyone used one to offer a mini review? https://youtu.be/kjP93YJFzgw Hi, Yes, I use a TR-A6 for Canon with my Jinbei HD600v. It works well, from a 7D or 5D III anyway, including remote M flash power adjustment and Supersync.
Jan 15, 2017 14:48 | #3 Thank you Steve
Jan 15, 2017 16:43 | #4 Does anybody know why the UK seems to be out of stock of these triggers? Steve
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info | Jan 15, 2017 17:25 | #5 Gungnir wrote in post #18245373 Does anybody know why the UK seems to be out of stock of these triggers? Ordered from ebay.com rather than ebay.co.uk but wondering why it was neccesary. It's a niche product. Many will be content with their original Jinbei triggers - and others will have moved on to higher spec lights than the HD600v. BTW, it's OK to order from Germany or France etc when required - less import duty risk, pre-Brexit, anyway.
Gungnir THREAD STARTER Senior Member More info Post edited over 6 years ago by Gungnir. (2 edits in all) | Jan 25, 2017 14:20 | #6 Arrived yesterday and have been using it today. Everything works as it should but there is an odd thing happening. Steve
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info | Jan 25, 2017 18:33 | #7 Gungnir wrote in post #18255254 Arrived yesterday and have been using it today. Everything works as it should but there is an odd thing happening. With the trigger attached but switched off and camera set to aperture or shutter priority the shutter speed stays at flash sync speed of 1/200. In the case of shutter priority I can select any shutter speed but as soon as camera AF/metering begins it goes back to 1/200 for the shot. Wary of having it attached now. Any ideas? Edit: It only does it if trigger is set to HSS. Hi, Which camera body & which Light, please. When I'm shooting with flash my camera is always in M - but I'll have a play later and report.
Jan 26, 2017 02:34 | #8 Jinbei HD600v with 5D3. Steve
OceanRipple* Senior Member 842 posts Likes: 175 Joined Dec 2014 More info Post edited over 6 years ago by OceanRipple*. | Jan 26, 2017 06:07 | #9 Gungnir wrote in post #18255254 Arrived yesterday and have been using it today. Everything works as it should but there is an odd thing happening. With the trigger attached but switched off and camera set to aperture or shutter priority the shutter speed stays at flash sync speed of 1/200. In the case of shutter priority I can select any shutter speed but as soon as camera AF/metering begins it goes back to 1/200 for the shot. Wary of having it attached now. Any ideas? Edit: It only does it if trigger is set to HSS. Yes, confirmed. I hadn't noticed as whenever I have the TR-A6 in place, I'm invariably in M on the camera - but you are correct. I'm testing with a 7D(original), my daughter has my 5DIII on extended loan!
Jan 26, 2017 07:06 | #10 Thankyou. Steve
| Latest registered member is semonsters 881 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
