Thread started 16 Jan 2017 (Monday) 12:18
How does Adobe RGB affect workflow unlike sRGB?
Luigi1234
Joined May 2016
Jan 16, 2017 12:18 |  #1
Hi,
I'm new to color spaces. I've read about Adobe RGB providing better color range in prints, that is if you export the raw file as Adobe RGB. But why do people speak of workflow? I use Lightroom. I thought a file is RAW until you apply a color space to it, but only when you're ready to convert it into a JPEG....
This is the kind of thing I read online:
"Adobe RGB requires special software and painstaking workflow not to screw it up."
agedbriar
Jan 16, 2017 13:37 |  #2
Luigi, I think you'd better stick with your previous thread, even if you have additional questions on color spaces.
People are missing you there.
tonylong
...winded
Gallery: 60 photos
Jan 16, 2017 19:04 |  #3
agedbriar wrote in post #18246235 (external link)
As was said, your previous thread has a ton of "stuff", wade through it!
It should be said that as we saw there are areas of "differences" in workflow preferences, those are things to wade through. I'd just start with KISS ("Keep It Simple, Stupid" :) )! In your Raw processor do your Raw editing, then put out the results for the intended output! Use sRGB for most stuff, aRGB if you will be printing to a compatible printer and if your setup "works" with aRGB (or ProPhotoRGB)! But take your time, and KISS!
Tony
tim
Light Bringer
Post edited over 6 years ago by tim.
Jan 17, 2017 15:55 |  #4
Until you understand color backwards and forwards, such as by reading and understanding this book (external link), use sRgb for everything. While Adobe RGB has some small theoretical advantages it depends on your subject and output medium, and if you do something wrong in your workflow you can mess up your color and have everything look really muted and dull. There is also some small, probably theoretical loss, when converting between color spaces, so I convert directly from RAW to the color space I need. Sometimes this means one set of images in one color space for my album manufacturer and another set in sRgb for the customer.
Only using sRgb avoids problems and will greatly increase your changes of producing good prints and files.
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Jan 17, 2017 16:38 |  #5
I use ProPhoto in PS. When I use the save for web tool I have the Convert to sRGB box checked. For prints I use the Edit - Convert to Profile tool when I'm done editing. I convert to sRGB. LR uses ProPhoto and I just choose sRGB when exporting.
Image Editing OK
tonylong
...winded
Gallery: 60 photos
Jan 17, 2017 17:32 |  #6
If you do work in Photoshop, well I learned from experience that it's not wise to keep an image in ProPhoto or even aRGB when you are saving for the Web, unless you have a very clear process to convert to sRGB! Otherwise, things can get real ugly when you post those photos to the Web! If you are going to use another color space in PS then you need a solid workflow "habit"!
Tony
Wilt
Post edited over 6 years ago by Wilt.
Jan 17, 2017 18:08 |  #7
  1. Only go from a 16-bit space to an 8-bit space
  2. Never ever convert from one 8-bit space to a different 8-bit space...even with a 16-bit space as the intermediate point
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 17, 2017 18:09 |  #8
If you lost it, here's your earlier thread on the subject, best to continue the discussion here;
https://photography-on-the.net …/showthread.php​?t=1474160
CDS' HOT LINKS
1,936 views & 2 likes for this thread, 7 members have posted to it and it is followed by 4 members.
1433 guests, 178 members online
