Is it possible, somehow, to shoot "tethered" directly to a FlatScreen TV from my 5D Mark IV (or Mark III)?
Perhaps via the HDMI somehow?
/Jocce
Jocce Senior Member More info | Jan 18, 2017 04:56 | #1 Is it possible, somehow, to shoot "tethered" directly to a FlatScreen TV from my 5D Mark IV (or Mark III)?
Jan 18, 2017 09:45 | #2 You could use the Canon EOS Utility on a PC to control the camera via WiFi or USB and use your TV as a display for the PC via its HDMI out, or I'm sure you could do the same with an Android-based device and the Canon mobile utility. I'm not sure if you're looking to control the camera with a separate device or if you're just looking to display pictures as they're taken via the camera, but with more information as to what you're trying to accomplish I'm sure others can direct you further. PhotographicMemoriesCT.com
Jan 19, 2017 02:16 | #3 TreeburnerCT wrote in post #18248222 You could use the Canon EOS Utility on a PC to control the camera via WiFi or USB and use your TV as a display for the PC via its HDMI out, or I'm sure you could do the same with an Android-based device and the Canon mobile utility. I'm not sure if you're looking to control the camera with a separate device or if you're just looking to display pictures as they're taken via the camera, but with more information as to what you're trying to accomplish I'm sure others can direct you further. -Joe I would like to directly from the camera, without any computer, phone or any other device display images on a 65" LCD-Flat Screen TV.
Jan 19, 2017 16:46 | #4 I believe that when you plug a display in via the HDMI port, that display will always be used instead of the LCD for image review and playback. So you can compose via the viewfinder and then when you playback the image it will show on whatever display is plugged-in to the HDMI port. -- Mark | Gear | Flickr
TeamSpeed 01010100 01010011 More info Post edited over 6 years ago by TeamSpeed. | Jan 19, 2017 17:19 | #5 Why not just use the wifi on the 5d4 to your phone or tablet? That is a perfect use of wifi. Past Equipment | My Personal Gallery
dasmith232 Senior Member More info | Jan 19, 2017 17:27 | #6 There are some bodies that have HDMI out but not WiFi (like the 5D3). In those cases, you can use a (sold separately) dedicated cable the connects to an HDMI monitor. Dave
Jan 20, 2017 01:52 | #7 bumpintheroad wrote in post #18249641 I believe that when you plug a display in via the HDMI port, that display will always be used instead of the LCD for image review and playback. So you can compose via the viewfinder and then when you playback the image it will show on whatever display is plugged-in to the HDMI port. I will try this the next time
Jan 20, 2017 01:53 | #8 TeamSpeed wrote in post #18249675 Why not just use the wifi on the 5d4 to your phone or tablet? That is a perfect use of wifi. Also an option, though a 65" Flatscreen that is already there gives the subject an easier look
Jan 20, 2017 01:53 | #9 dasmith232 wrote in post #18249689 There are some bodies that have HDMI out but not WiFi (like the 5D3). In those cases, you can use a (sold separately) dedicated cable the connects to an HDMI monitor. With that you'll project what's on the back monitor to the flat screen. However, you don't get the same resolution on that mode as looking at the image when tethered. As long as the resolution is not extremly low, that's not a problem for this kind of use.
TeamSpeed 01010100 01010011 More info | Yes you can do live view, and if you have a 10" tablet, or can cast you phone or tablet to a TV it will show there. Past Equipment | My Personal Gallery
Jan 20, 2017 06:19 | #11 TeamSpeed wrote in post #18250134 Yes you can do live view, and if you have a 10" tablet, or can cast you phone or tablet to a TV it will show there. But i would prefer NOT using LiveView...
TeamSpeed 01010100 01010011 More info Post edited over 6 years ago by TeamSpeed. (9 edits in all) | Jan 20, 2017 07:42 | #12 Jocce wrote in post #18250137 But i would prefer NOT using LiveView... But the idea of Casting is good (as long as the TV supports it or a Chromecast is installed )/Jocce You have no choice really, you will have to be in live view to show anything at all. The sensor has to see the subject material in order to display it on HDMI, or to send it through wifi. DSLRs have a mirror that block the sensor if you are not in live view, and therefore all the sensor sees is "black". Past Equipment | My Personal Gallery
yellowt2 Senior Member 270 posts Likes: 70 Joined Sep 2009 More info | Jan 20, 2017 13:42 | #13 TeamSpeed wrote in post #18250168 You have no choice really, you will have to be in live view to show anything at all. The sensor has to see the subject material in order to display it on HDMI, or to send it through wifi. DSLRs have a mirror that block the sensor if you are not in live view, and therefore all the sensor sees is "black". From what the OP said, he doesn't need the subjects to have a constant live view feed, he just wants them to be able to see an image review.
TeamSpeed 01010100 01010011 More info | Same solutions work for that as well.... but still question the lack of desire for live view when doing badge photos? Past Equipment | My Personal Gallery
| Latest registered member is griggt 1118 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
