Thread started 19 Jan 2017 (Thursday) 02:27
Does it matter where I shoot the strobe in the umbrella?
Jocce
Gallery: 12 photos
Joined Jun 2012
Jan 19, 2017 02:27 |  #1
Just got some new toys yesterday, some Phottix Odin II Transmitter and Receivers :)
So far I mainly shoot with umbrellas. And found out yesterday that when I put the HotShoe strobes on the receivers the get kind of high up.
Without receiver (already kind of far up)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/01/3/LQ_835599.jpg
Image hosted by forum (835599) © Jocce [SHARE LINK]
With receiver (even further up)
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/01/3/LQ_835598.jpg
Image hosted by forum (835598) © Jocce [SHARE LINK]
(Hard to see in the images but the flash is pointing fairly high up in the umbrella...)
Does this matter at all?
If so, how do I fix it?
/Jocce
Feel free to correct my English. I'm from Sweden ;)
My Website (external link)
Fotointresse.se (external link)
Twitter (external link)
Bassat
"I am still in my underwear."
Joined Oct 2015
Post edited over 6 years ago by Bassat.
Jan 19, 2017 03:01 |  #2
I use the same type of setup with 580EX II/YN-622c. On the 580 I can tilt the flash head down 7 degrees. I also deploy the diffusion panel. Both together help cut down the 'hotspot'. This is one situation where a Sto-Fen diffuser may actually help. Looks like you are shooting reflector umbrellas. I find these generate less of a 'hotspot' than the shoot-through style.
EDIT:
I did once try laying the flash down and rubber-banding it to the flash stand. Awkward, looks stupid, didn't appear to help.
Jocce
Gallery: 12 photos
Joined Jun 2012
Jan 19, 2017 04:06 |  #3
Bassat wrote in post #18249043 (external link)
EDIT:
Yes, I can also tilt the head down, but it seems that it still shoots in the wrong "spot".
I also have some shoot-through umbrellas that I use sometimes.
/Jocce
nixland
Jan 19, 2017 04:14 |  #4
There are several commercial umbrella bracket in the market that will position your flash head close to the axis. For DIY ones, these are some setup options, found on internet.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/01/3/LQ_835610.jpg
Image hosted by forum (835610) © nixland [SHARE LINK]
Jocce
Gallery: 12 photos
Joined Jun 2012
Jan 19, 2017 04:17 |  #5
nixland wrote in post #18249072 (external link)
Hosted photo: posted by nixland in
./showthread.php?p=182​49072&i=i37524641
forum: Flash and Studio Lighting
Thanks. I will have a look at this!
But the main question still is:
Does it matter? Does it change the light?
/Jocce
nixland
Jan 19, 2017 06:10 |  #6
Jocce wrote in post #18249074 (external link)
/Jocce
I use silver reflective umbrella sometimes with speedlite and it does matter.
White reflective umbrella could be more forgiving, but still I believe it matters do to the design shape of umbrella.
This is one of the example on the internet that might show you the problem.
http://www.bokehblog.c​om …-Umbrella-or-Softbox.html (external link)
RicoTudor
Joined Jul 2014
Jan 19, 2017 09:05 |  #7
Even for a white umbrella, uniform distribution will improve speculars on glossy surfaces. On glass and chrome surfaces, the improvement will be obvious (not that umbrella reflections are pretty). The ubiquitous Manfrotto umbrella mount has your problem, so I use ordinary grip gear for complete flexibility. I could position the flash right on the umbrella shaft if I wanted:
IMAGE: http://patternassociates.com/rico/fm/umbrella014.jpg
IMAGE: http://patternassociates.com/rico/fm/umbrella015.jpg
Canon, Nikon, Contax, Leica, Sony, Profoto.
dmward
Gallery: 29 photos
Jan 19, 2017 09:09 |  #8
Its relatively easy to do your own test.
turn the power down on the speedlite, then use a low ISO and F stop so you get the light pattern on the umbrella created by the speedlite.
If you don't have one of the centering brackets just use a big rubber band or a velcro strap to hold the speedlite head on the center shaft of the umbrella for the second test.
Its also important to select a zoom setting and position the speedlite so it fills the whole umbrella rather than just part of it.
Once you've seen what the light pattern is on the umbrella using both mounting options use the setup to make some pictures to see how the light looks on a subject.
You should be able to see the difference.
smaeda
Joined Aug 2012
Jan 19, 2017 09:14 |  #9
https://www.amazon.com …sr=8-1&keywords=s-bracket (external link)
Here is another bracket that a lot of us use that help this situation. It also doubles as quick box mount and bowens/elinchrom mount.
https://instagram.com/​shintarodesign (external link)
www.shintarodesign.com (external link)
https://www.facebook.c​om/shintarodesign (external link)
Sony A7iii, Irix 15mm f2.4, Tamron 28-75mm f2.8, 85mm f1.4, Sony GM 70-200mm f2.8, Tamron 70-180mm f2.8
Jocce
Gallery: 12 photos
Joined Jun 2012
Jan 19, 2017 09:17 |  #10
dmward wrote in post #18249205 (external link)
I'll try to do a test some day :)
/Jocce
Jocce
Gallery: 12 photos
Joined Jun 2012
Jan 19, 2017 09:18 |  #11
smaeda wrote in post #18249209 (external link)
That's a nice solution, though it adds quite a volume to the "on location-kit". But it seems to be a nice solution though :)
Seen any Ebay-knock offs?
/Jocce
invi2003
Gallery: 437 photos
Jan 19, 2017 09:41 |  #12
/Jocce
i've been doing research now that im trying my hands at portrait and I remember this video which warns about your issue.
Take a look - https://www.youtube.co​m/watch?v=T0fpgzWxppc (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Post edited over 6 years ago by CyberDyneSystems.
Jan 19, 2017 09:47 |  #13
Jocce wrote in post #18249212 (external link)
/Jocce
I was going to suggest the same.
They can be had for about $19.00 on Amazon. I've not seen them any cheaper on Ebay, there are already multiple brands on Amazon. It used to be that the "Neewer" version was the lowest price, but I am seeing the Godox units down at $19.00 now too. they are all one and the same (I have two Godox and two "Neewer")
CDS' HOT LINKS
K ­ Soze
Gallery: 89 photos
Joined Dec 2011
Jan 19, 2017 09:59 |  #14
RicoTudor wrote in post #18249202 (external link)
Kind of weird set up to me. Big money in great stands and then speed lights instead of strobes?
I try to make art by pushing buttons
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 6 years ago by TeamSpeed. (2 edits in all)
Jan 19, 2017 10:02 |  #15
I actually run something similar. When I do backlighting of subjects using black backgrounds, I use speedlights and reserve my strobes for the front of the subject material. Nothing wrong with 580EX units and umbrellas, they work pretty good.
I need to get some Godox S-Type mounts for my flashes and strobes, to get the light down closer to the center, as well as have a more stable setup than the flash stands I am using now. :(
The AD200 looks interesting... But I should be set on lighting for now, I cannot look at any more toys. :D
9,194 views & 17 likes for this thread, 18 members have posted to it and it is followed by 7 members.
1125 guests, 170 members online
