Thread started 19 Jan 2017 (Thursday) 10:51
Normal for a Canon 400 f/5.6 AF?
Larry ­ Johnson
Joined Sep 2011
Jan 19, 2017 10:51 |  #1
The AF on my recently purchased used 400mm is almost always quick to respond on my 7D2. However, sometimes it fails to enagage when I ask it to make a huge swing on the focus ring, like going from mfd to infinity, regardless of whether it's set to 3.5m-infinity or 8.5m-infinity. I generally have the lens set to 8.5m-infinity. The camera is set to AF option 2 and I'm generally tracking BIFs, bump focusing. Lighting is good and I haven't noticed any similar issues when using a 100-400 I. Does this sound like an issue with the lens.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
BigAl007
Gallery: 556 photos
Jan 19, 2017 15:00 |  #2
NFN, Normal for Norfolk maybe ;). I bet you have the AF set so that if it is not possible for the AF to calculate a correct focus focus for the system to not drive. I think the menu item is Disable drive if AF not possible. It's to stop the lens from racking from end to end if there is nothing to focus on. Useful if you temporarily lose the subject off the AF point in AI Servo with a long lens. In that situation you probably don't want the lens to run. The thing is that with long lenses it is quite easy for the image to be so defoused when at one end of the range that it can't detect anything at the other end. It is very noticeable with my 150-600mm at 600mm. If it's focused under about 50' it won't then run out to infinity. I'm ready to accept that as my 50D doesn''t allow tracking sensitivity adjustment, so if I lose the subject off the point even for a second it would otherwise run in and out. By which time I will have lost the subject.
Alan
don1163
Gallery: 27 photos
Joined May 2015
Jan 19, 2017 15:08 |  #3
I had this set on my 6D and was convinced my 500f4 was at fault....I even dropped the lens into the repair centre, then someone on here suggested I check the camera setting and that was the problem....I felt a bit silly.
1DX, 500L f4, 70-200L f2.8II, 100L f2.8 macro ,16-35 f4, 1.4xIII, Metz 64-AF1
BigAl007
Gallery: 556 photos
Jan 19, 2017 15:19 |  #4
don1163 wrote in post #18249515 (external link)
Oh yes that moment when you realise you have had a Lightrules moment. For everything else there is Amex :).
Alan
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Jan 19, 2017 15:51 |  #5
BigAl007 wrote in post #18249526 (external link)
Alan
We really need to revive that thread! :lol:
Larry ­ Johnson
Joined Sep 2011
Jan 19, 2017 19:12 |  #6
BigAl007 wrote in post #18249508 (external link)
Alan
Yes, as a matter of fact I do have the "Lens Drive when AF impossible" set Off. It's been set that way for sometime to prevent the AF from hunting, just as you described and as canon recommends for supertelephotos. I've never noticed my other lens, a 100-400 v.1, acting similarly. That's why I asked the question.
Ain't Nature Grand!
1,879 views & 0 likes for this thread, 4 members have posted to it.
1689 guests, 140 members online
