Thread started 19 Jan 2017 (Thursday) 19:53
7dmk2 AF Tracking Question
snegron
Joined Jul 2012
Jan 19, 2017 19:53 |  #1
Not sure what I am doing wrong, but I tried setting my AF to "Case 2", selected it, but it didn't seem to work for me. Focus won't lock on to one subject.
Settings I had were manual, AI servo. I'm guessing there is a step I am missing to actually select "Case 2". Probably highlighted but not selected maybe?
Today I tried shooting a soccer game and the AF would not lock on the player.
Larry ­ Johnson
Joined Sep 2011
Jan 19, 2017 20:29 |  #2
If you selected it properly, case 2 will be shown on the menu screen.
There could be a number of reasons why you didn't get AF to lock on. How many focus points do you have activated? What lens are you using. Can you post a photo.
Ain't Nature Grand!
Shooting 7D2 with Canon 400mm, f/5.6.
60D, canon 18-135 EFS, and 1.4 extender in the bag.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 19, 2017 20:35 |  #3
1) As requested, are you controlling which AF points, or do you have all points turned on?
2) Is your lens AF switch set to on?
3) Do you have AI Servo or One Shot turned on?
snegron
Joined Jul 2012
Jan 19, 2017 21:02 |  #4
TeamSpeed wrote in post #18249850 (external link)
- Yes, I am controlling which AF points I am using.
- AF selected on lens (70-20mm 2.8L)
- AF Servo selected
My camera is focusing; it's just not locking focus. I had way too many shots focused on the background instead of the players.
Also, I tried an experiment. I focused on an object 20 feet away from me. I left my finger pressing the shutter release button, panned the camera away but the camera refocused on whatever I pointed at despite leaving my finger pressed on the shutter release button. In other words, it did not lock focus.
snegron
Joined Jul 2012
Jan 19, 2017 21:03 |  #5
Larry Johnson wrote in post #18249846 (external link)
It shows on the menu screen, but for some reason it is not letting me select it.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 6 years ago by TeamSpeed. (5 edits in all)
Jan 19, 2017 21:08 as a reply to  @ snegron's post |  #6
If you haven't taken focus off the shutter button, then half-pressing the shutter would engage AF the entire time, wouldn't it? That means it would shift focus where you put your AF point.
When you say you want focus locked, do you mean you want to focus on something, then not have it not change as you aim at other things? That sounds like you want to turn off AF from the shutter, then use AF-ON on the back to set your focus, then let off AF-ON to keep focus where it was. If so, that is not case 2, you want to customize your buttons. Case 2 is used for more fast paced action where the object is obscured for very short times, and then comes back into focus. If it doesn't see that object again in short order, it will refocus. You also have to be very good at keeping the AF point on the subject, even as it is temporarily obscured.
Some links:
http://learn.usa.canon​.com …os7dmk2_afGuide​book.shtml (external link)
https://www.youtube.co​m/watch?v=pYFMVnCDqig (external link)
My own use of the 7D2 and its AF system to track players during a game.
IMAGE: https://photos.smugmug.com/Sports-Events/Mad-Ants-20152016/Mar-22/i-g8RWjqV/0/X2/216A6702-X2.jpg
Bassat
"I am still in my underwear."
Joined Oct 2015
Jan 19, 2017 21:35 |  #7
If I understand the 7D2 properly, which Case you have dialed in means nothing. Cases are only storage bins for the slider-settings they contain. If you set up all Cases the same, they will all behave the same. Case is not the problem.
Larry ­ Johnson
Joined Sep 2011
Jan 19, 2017 21:50 |  #8
This video may have the answer. I didn't watch it all.
https://www.youtube.co​m/watch?v=NpFezdEC4d4 (external link)
Ain't Nature Grand!
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Post edited over 6 years ago by digital paradise.
Jan 20, 2017 08:40 |  #9
It has nothing to do with case numbers. Case numbers kick in after the initial AF acquisition. They control tracking characteristics. Something else is going on.
Image Editing OK
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jan 20, 2017 09:47 |  #10
I am still hung up on this comment... The behavior described is exactly what the camera should be doing. No set of AF settings will stop focusing as the scene changes while in AI Servo mode and AF is active. Those settings are very discrete and only are effective during bursts of action, but also depends how good you are at tracking your subject with the AF point. I am a bit confused on what the expectation really is.
snegron wrote in post #18249867 (external link)
Jethr0
Gallery: 91 photos
Joined Aug 2012
Jan 20, 2017 09:55 |  #11
Are you saying that only Case 2 has this behavior?
Will the focus lock on a stationary object?
Where is your focus selection set to? I use the center group of AF points on mine most often and works well.
www.jefflowe.ca (external link)
Instagram: https://www.instagram.com/jeff​lowe.ca (external link)
MakisM1
Gallery: 50 photos
Joined Dec 2011
Jan 20, 2017 09:56 |  #12
I don't have the 7DII but I sincerely doubt if the AF philosophy is different than my 5DIII...
The OP said that he selects the AF point and as he pans, the AF point picks up focus at where its new position is.
There are two ways to use the AF point.
One is to select a single point for AF and then move it around the matrix of AF points (with the joystick or whatever the 7D is using to move things around).
The other is to select ALL points. You then use the joystick to select your INITIAL AF point and that point will lock onto the subject and move around the AF point matrix automatically.
I suspect that the OP used the first way of doing things, but he expects the results of the second.
Gerry
Jethr0
Gallery: 91 photos
Joined Aug 2012
Jan 20, 2017 10:00 as a reply to  @ MakisM1's post |  #13
^^Initial focus lock is the same AFAIK.
The 'Cases" affect how the locked focus point stays locked onto the subject despite it moving around.
If the OP has messed around with some of the settings inside the case setting that may be throwing things off.
Archibald
You must be quackers!
Gallery: 789 photos
Jan 20, 2017 10:06 |  #14
- AF Servo selected
There might be an issue here of what is meant by "lock". AF Servo means continuous focus. It won't lock. It will refocus when the AF points are over other things.
Jethr0
Gallery: 91 photos
Joined Aug 2012
Jan 20, 2017 10:09 |  #15
Archibald wrote in post #18250291 (external link)
^ I took it to mean it locks on a subject and constantly maintains that focus.
unless he's pushing the focus lock button in which case that would render the servo case 2 lock inoperable.
9,169 views & 3 likes for this thread, 12 members have posted to it and it is followed by 6 members.
1680 guests, 138 members online
