Thread started 22 Jan 2017 (Sunday) 07:46
Canon 60D image upside down upon play back
blackgold59
Joined Feb 2013
Jan 22, 2017 07:46 |  #1
All of a sudden one day when I grabbed my camera and turned it on I noticed after taking a picture and review came up, it was upside down. Now if I turn out the back screen and take the picture with it out instead of folded in, the picture is correct.
Any idea's on what this is? And idea to fix it also, should be cheaper to fix then update camera.
dasmith232
Gallery: 40 photos
Joined Nov 2012
Jan 22, 2017 08:20 |  #2
This is probably obscure or highly unlikely, but have you installed or attempted to install Magic Lantern?
Magic Lantern is a software add-on to the operating system in the camera. Some people attempt to install it, but don't do it correctly. ML has a feature to turn the display upside down.
Dave
Mostly using Canon bodies with lots of different lenses and flash.
waterrockets
Joined Jun 2010
Post edited over 6 years ago by waterrockets. (2 edits in all)
Jan 22, 2017 08:43 |  #3
It's possible that the flip screen position sensor has gone bad, or bad only in the closed position.
What's it do when flipped forward (like selfie orientation), in live view and in image review?
1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
blackgold59
Joined Feb 2013
Jan 22, 2017 11:51 |  #4
No, I did not install magic lantern. Actually I did nothing, just picked up the camera again one day and seen it.
When its flipped forward into position is when it's upside down, if I turn it out too the side its correct.
John ­ from ­ PA
Joined May 2003
Post edited over 6 years ago by John from PA. (3 edits in all)
Jan 26, 2017 08:52 |  #5
1st, double check the menu setting for image rotation.
Check the thread at http://community.usa.c​anon.com …-Display-Issue/td-p/50509 (external link). Drill down a bit to some camera body photographs (time on reply is 08-12-2016 12:22 AM) as someone found a fix relative to the sensor.
Otherwise I'd reflash the firmware and then retest.
5,592 views & 1 like for this thread, 4 members have posted to it and it is followed by 2 members.
506 guests, 119 members online
