Thread started 23 Jan 2017 (Monday) 05:29
Anyone sold his (uwa) bulbous lens cause of flare ?
CanonYouCan
Post edited over 4 years ago by CanonYouCan. (2 edits in all)
Jan 23, 2017 05:29 |  #1
I bought a 14mm 2.8 and tested it for the first time @ f8 outside during a reasonable sunny day.
As expected due to the bulbous form of the lens I had flare in a range of pics, so I took new ones from other angles.
Did anyone sell his lens allready for this reason only or did you manage after a while and did you check for other angles?
I still have the Tokina 17 3.5 which has no flare (no bulbous form) but 3mm wider is a lot is a lot on the wide side.
Sony A7 III | Metabones V | Canon 16-35 F4 L | Sigma 85 1.4 Art | 70-200 2.8L II
Lighting : Godox AD600B TTL + Godox V860II-S + X1T-S
Modifiers: 60cm Collapsible Silver Beautydish + grid | Godox 120cm Octagon softbox + grid + Speedlite Flash bender
Tripod: Vanguard Alta 253CT carbon
CheshireCat
Post edited over 4 years ago by CheshireCat. (3 edits in all)
Jan 23, 2017 07:01 |  #2
The answer is no, but I dumped the EF 50/1.8 v2 because of flare.
Flare does not depend on how bulbous the lens is, but on how good the design and materials (glass types, coatings, ...) are. As usual, you get what you pay for.
UWA are usually more sensible to flare just because it is more likely to have the sun in the frame. Also, UWA for reflex cameras are retrofocus designs and require a complex optical scheme with many elements, which does not help.
1Dx, 5D2 and some lenses
dasmith232
Gallery: 29 photos
Joined Nov 2012
Jan 23, 2017 07:45 |  #3
Also, flare comes in many forms. I agree that flare can be bad, but I don't assume that all flare is bad.
In the 1970's seeing flare was more common even in (outdoor) portraiture. Is was "romantic". In this picture, there is some flare that is a mild loss of contrast and very slight discoloration near the sun. And it happens to be what I wanted.
For me, it's a combination of equipment and intent.
Photo from dasmith232's gallery.
Dave
Mostly using 5DIII with lots of different lenses and flash.
Bassat
"I am still in my underwear."
Joined Oct 2015
Jan 23, 2017 09:57 |  #4
I had the Rokinon 14mm f/2.8. I sold it because it wasn't wide enough, not because of flare. I just went through my library and have NO photos from this lens with the 'colored sun-spot' type of flare, and only a handful that may be exhibiting 'loss of contrast' flare. IMHO, this lens performs very well wrt flare.
BTW, I replaced the Rok 14 with a Rokinon 12mm f/2.8 FE. I like it. Also own a Sigma 15mm FE, which I really don't use after getting the Rok 12. Just too lazy to sell it.
CheshireCat
Jan 23, 2017 18:18 as a reply to  @ dasmith232's post |  #5
Nice shot, though I would call it sunstar (diffraction) rather than flare (unwanted reflections).
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Jan 23, 2017 18:57 |  #6
I kinda agree with the fact that the shape of the lens element isn't the deciding factor, the only reason it makes more of a difference is because it is more likely to be hit by the sun. In certain conditions, no amount of coating is going to stop flare.
I just use my hand to shield the front element of my tokina 16-28 when outside in full sun. Never had a problem with that lens otherwise.
dasmith232
Gallery: 29 photos
Joined Nov 2012
Jan 23, 2017 19:57 |  #7
CheshireCat wrote in post #18253624 (external link)
Thanks. Yeah, mostly star and the flaring is very mild just below the star. I do have other examples of worse flares with that lens (a little bit) and others (more).
Dave
Gallery: 15 photos
Joined Jun 2011
Jan 24, 2017 05:09 as a reply to  @ dasmith232's post |  #8
typically when people complain of flare i assume they are talking about flare away from the source of the strong light.
Ghosting flare as seen here: https://photographylif​e.com/what-is-ghosting-and-flare (external link)
example here: https://photography-on-the.net …showthread.php?​p=16184739
ebiggs
Gallery: 24 photos
Joined Oct 2012
Jan 24, 2017 09:13 |  #9
dasmith232 wrote in post #18253151 (external link)
Very nice shot Dave.
My personal favorite 'bulbous' lens is the Tokina AT-X 16-28mm f/2.8 Pro FX. It is a fantastic lens. Maybe better than either the Canon or Nikon offerings in this focal length. Plus it kicks ass on price!
G1x, EOS 1Dx, EOS 1D Mk IV, ef 8-15mm f4L,
ef 16-35mm f2.8L II, ef 24-70mm f2.8L II, ef 70-200mm f/2.8L IS II,
Sigma 150-600mm f5-6.3 DG OS HSM Sport
*** PS 6, ACR 9.3, Lightroom 6.5 ***
dasmith232
Gallery: 29 photos
Joined Nov 2012
Jan 24, 2017 10:37 |  #10
ebiggs wrote in post #18254136 (external link)
A friend of mine has that lens. Cheap and sharp. Not a common combination. If I think about it too much then I'll start falling into GAS yet again. I don't need more of that.
So how can I deal with your comment? Hmm, shiny object! Huh? What were we talking about...?
Dave
2,065 views & 2 likes for this thread
Latest registered member is kenf
685 guests, 314 members online
