Thread started 27 Jan 2017 (Friday) 01:18
ND-Filters - Strength and more?
Jocce
Gallery: 12 photos
Joined Jun 2012
Jan 27, 2017 01:18 |  #1
Just upgraded from my 17-40/2,8 to a 16-35/2,8 II.
This means getting new filters (82mm on the 16-35).
So, any recommendations on brands? Most bang for the buck? (Been using B+W before and I am satisfied, but always nice to see what is out there :) )
What strength do you guys use on the ND-Filters, and for what shooting?
Anyone using the adjustable ND-Filters? Or don't they give the same image quality?
/Jocce
Feel free to correct my English. I'm from Sweden ;)
My Website (external link)
Fotointresse.se (external link)
Twitter (external link)
gremlin75
Jan 31, 2017 21:36 |  #2
Jocce wrote in post #18256580 (external link)
/Jocce
I'd recommend the Firecrest filter from Formatt-HiTech. They are the most neutral (least amount of color cast) I have used.
I just use a 4 stop (1.2) and 10 stop (3.0). I use them for smoothing out water in waterfalls, rivers, and sometimes lakes. Usually use them in conjunction with a B+W CPL
hobinsohn
Gallery: 20 photos
Joined Mar 2016
Mar 02, 2017 15:46 |  #3
from my experience, adjustable ones are hit or miss. some of them, as you hit its limit, you will get some kind of weird dark lines.
I use ND4 and ND1000, same as gremlin75. I have stacked them before, but in most cases ND1000 is about most i need.
Use them mostly to capture movements in water and clouds.
I would recommend that you go bigger than you need to. 1. to help with vignetting (some less expensive filters sometimes get vignetting on the corners...) 2. you can use those filters on smaller threads using step-up rings.
If you are really serious about using filters on landscapes and etc, you can invest in nicer LEE filters so you can use graduated filters too.
They make circular graduated filters, but you don't have the same flexibility LEE or other square filters offer. Basically your compositions are limited when using circular grads.
Down side of the square filters generally are cost... and bulkiness if you hike or travel a lot.
Don't forget the polarizer to cut through glares!
1,683 views & 0 likes for this thread, 3 members have posted to it and it is followed by 2 members.
1118 guests, 169 members online
