Hi all, I am new to your forum.
I am a wildlife photographer and have had a recent issue with the 600mm F4-2. Early last week I did a shoot and no problems. Later last week did a bird shoot and high speed burst on my 7d Mk2 ran at about 5fps not 10fps. Put my other 7d Mk2 on the lens and it did the same thing. All other lens functions seem fine. If I put on any other lens I have on either camera they have max burst, no problems. It is just the 600 that does this.
I have shot thousands of photos thru this lens and both cameras without any problems. Both cameras are set up the same. AI servo, spot metering, single point focus, shoot raw files, etc. I have tried different lens settings, ex. mf then af, with the same result. Single shot, and silent mode shooting work on both cameras. The lens has never been dropped or even bumped hard. Saying that, it has been carried a lot in the bush on a tripod, with camera, battery grip, teleconverter, on a RRS tripod with a gimbal head. I am guessing but suspect possible deflection in the mounts, a contact, etc. etc. Just a guess.
Hopefully someone out there has had a similar problem like this and a possible solution. I can still use it as I primarily use this setup in single shot mode now. I use a 300 f.28 with 1.4 teleconverter for birds in flight. By the way both cameras have max burst with the 300 setup.
Thanks so much in advance for your suggestions
Colonel4446
