I have removed card/RAW photos from Canon DSLR, renamed photos and without changing them moved back to card and inserted camera. Canon DSLR can't recognize photos...It can't play them. Why? Anybody can explain this?
Thanks!
oharing Senior Member 564 posts Likes: 23 Joined Apr 2010 Location: Miami, FL More info | Feb 03, 2017 19:02 | #1 I have removed card/RAW photos from Canon DSLR, renamed photos and without changing them moved back to card and inserted camera. Canon DSLR can't recognize photos...It can't play them. Why? Anybody can explain this?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 6 years ago by Wilt. | Feb 03, 2017 19:27 | #2 This inability to display files moved TO a Canon digital camera has always been true! I first encountered this with the Canon G2 back around 2002. Apparently there is an internal (on the memory card) file which has an entry which the camera looks at for each photo that it displays; no entry, no display of that file. That's the way it was explained to my by someone at Canon's tech support. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Feb 03, 2017 19:36 | #3 Wilt wrote in post #18264051 This inability to display files moved TO a Canon digital camera has always been true! I first encountered this with the Canon G2 back around 2002. Apparently there is an internal (on the memory card) file which has an entry which the camera looks at for each photo that it displays; no entry, no display of that file. That's the way it was explained to my by someone at Canon's tech support. In fact, you cannot even copy a photo file, alter it with a program like Photoshop or Paint Shop Pro, and copy that file back to the memory card, as the entry in the internal file does not point to the altered version of the file!
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Feb 04, 2017 00:03 | #4 No explanation given for rationale. Just is that way You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Feb 04, 2017 09:49 | #5 I think it is a result of the Design Rules for Camera Filesystems specification. This is a specification from one of the Japanese Camera manufacturers trade associations, the names seem to change periodically, that allows memory cards to be awapped between different cameras without ill effect. Although a Japanese specification it seems to have been adopted worldwide by most manufacturers. It is why all cameras use the same basic folder structure. As I understand things part of this specification basically says if you did not create the file, then you do not touch the file, even if it is in "your" location within the file structure.
TomReichner "That's what I do." 17,636 posts Gallery: 213 photos Best ofs: 2 Likes: 8386 Joined Dec 2008 Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot More info | Feb 04, 2017 11:17 | #6 . Wilt wrote in post #18264051 Apparently there is an internal (on the memory card) file which has an entry which the camera looks at for each photo that it displays; no entry, no display of that file. That's the way it was explained to my by someone at Canon's tech support. In fact, you cannot even copy a photo file, alter it with a program like Photoshop or Paint Shop Pro, and copy that file back to the memory card, as the entry in the internal file does not point to the altered version of the file! . "Your" and "you're" are different words with completely different meanings - please use the correct one.
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Feb 04, 2017 16:17 | #7 Tom Reichner wrote in post #18264453 . . This sounds like the perfect kind of thing for Magic Lantern to override. . .
tonylong ...winded More info | Feb 04, 2017 22:17 | #8 So, let's get down to basics: Tony
TomReichner "That's what I do." 17,636 posts Gallery: 213 photos Best ofs: 2 Likes: 8386 Joined Dec 2008 Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot More info Post edited over 6 years ago by Tom Reichner. (2 edits in all) | Feb 04, 2017 23:14 | #9 BigAl007 wrote in post #18264704 If you were to allow the viewing of images from other devices you would need to implement a complete file browser system, as well as custom image viewing software, along with all it's support routines, that will now have to do a lot more work to get the image on screen. It will also, with out doubt, be a LOT slower in operation. . "Your" and "you're" are different words with completely different meanings - please use the correct one.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Files will be on the card and viewable on PC, but invisible to the camera. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
JWdlft Senior Member 336 posts Likes: 67 Joined Feb 2013 More info Post edited over 6 years ago by JWdlft. (4 edits in all) | Feb 05, 2017 07:35 | #11 oharing wrote in post #18264040 I have removed card/RAW photos from Canon DSLR, renamed photos and without changing them moved back to card and inserted camera. Renaming is the problem. Canon only recognises IMG_xxxx.JPG and its raw format _MG_xxxx.CR2. It will show those on the screen if you copy them to a photo folder on the card.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Feb 05, 2017 09:29 | #12 JWdlft wrote in post #18265168 Renaming is the problem. Canon only recognises IMG_xxxx.JPG and its raw format _MG_xxxx.CR2. It will show those on the screen if you copy them to a photo folder on the card. My 60D "cannot play back image" if it's not native resolution, 5184×3456, so I resized the canvas of a smaller image made in Paintshop Pro to 5184×3456, renamed it to IMG_9150.JPG, copied it to the camera folder and the camera displayed it. Remember that Canon will start numbering images from the highest IMG_xxxx number in the folder, or something like that. Edit: Canon will start numbering images from xxxx, not start REnumbering. Interesting, that behavior is different from my own experiences. Canon changed something somewhere along the line to more current cameras. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is semonsters 1039 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
