AlanU wrote in post #18272596
With HSS available now with the the EF-X500 flash it's no different having a focal plane shutter on a Fuji X-t1, 5dmk4, D810 etc.
However I can see the benefits of "NOT" using an electronic shutter for faster shutter speeds.
I'll have to admit I've seen absolutely no major differences in photos of many X100 users that posted photos compared to a run of the mill Fuji interchangeable body with a slapped on 27mm f/2.8 for good/ideal lighting.
Due to the small form factor of fuji bodies I'd rather have an XT20 with 23mm f/2 with a 35mm or 56mm in my coat pocket
Yes everyone is different. I shoot primes equally as much as zooms and I would feel some form of limitation with a fixed lens. I guess everyone will need to test an x100 or force to use a 1 prime all of the time.
HSS is not the same thing as a leaf shutter... not only that, but you're restricted to using ONLY the EF-X500, a $450 flash... with the X100T/F you can sync to 1/2000s with any flash, even the in-body flash.
I'm not sure what your point was with the electronic shutter comment...?
And again, you're glossing over the other advantages of the X100 line over one of the other ILC's with the 27mm (which is a fantastic lens); Built in ND filter, 1-stop faster lens, significantly closer focusing, etc.
We get that the X100 doesn't work for you... the point is that for the particular individual who started this thread the X100F sounds ideal, it's not about what's best for you, it's about what's best for the TS.
cug wrote in post #18272661
HSS via flash and focal plane shutter is different from HSS via leaf shutter. A leaf shutter based camera needs a lot less flash power than HSS on a focal plane shutter.
This.
The leaf shutter and the hybrid viewfinder were the two biggest draws for me to trade my X-E2 for an X100T. If I had to live with only one camera it would for sure be my X-Pro2 because I love having multiple lens choices, but the benefits of the X100 line are clear for anyone willing to look.
Britania757 wrote in post #18272548
I am able to fit my X100T in my hoodie, coat, shorts pocket as long as I'm not using the lens hood which is less often these days. I own an Xe-2 along with my X100T and I am 99% more likely to grab the X100T. If you just want to take photos and not have to invest in new glass and want something small, I say go for the X100F.
I bought a smaller hood for my X100T the very day I bought it... never been a fan of the vented lens hoods. I highly recommend the hood I got, not only is it a lot smaller than the original hood, but it protects the lens better.
Here's the hood I use; https://www.amazon.com …=sr-1&keywords=X100t+hood
And no, it does not vignette, and yes, it does seem to block just as many (if not more) flares
Though admittedly it's not as stylish.
