Having issues. Bit of a noob when it comes to off camera flash so bear with me. Have a new 680EX II RT fitted to the X1-C receiver and set to Master via Transmission from the XC-1T on my EOS5DSr. All good. Group B Channel 1, I have all set in the Camera Menu as needed and set zoom on the Flash in ETTL and all is good. However, I scroll through to Menu 4 where I should be able to access the HSS setting but when I select that it immediately disables. I can't for some reason set the HSS? Also that menu system is weird, or it may be me, but I only have one stab at the control and then have to scroll through the menu's to get to #4 again? Bit of a PITA on that one...
Any thoughts? Overlooking the obvious or?
Cheers,
Mark.
