FORUMS Forum FAQ and Information Forum Talk
Thread started 17 Feb 2017 (Friday) 15:47
"Image Failed to Load"
LonelyBoy
Gallery: 84 photos
Joined Oct 2014
Feb 17, 2017 15:47 |  #1
I'm getting a lot of "Image Failed to Load" white boxes where images should be. I started noticing it and assumed they were dead links (I first noticed in some old photo threads) but then clicked on one on a whim and it loaded - that one was Flickr, but it happens on forum gallery images too. Not all the time, but sometimes.
I am on cable, so I'd assume it shouldn't be a speed issue, but also shouldn't it just load slowly instead of failing if speed were an issue?
https://www.flickr.com​/photos/127590681@N03/ (external link)
I love a like, but feedback (including CC) is even better!
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Feb 17, 2017 15:59 |  #2
LonelyBoy wrote in post #18276812 (external link)
It may be an issue caused by a browser "giving up too fast" when image URL is not immediately contacted, browser bugs are also possible. I have seen that happen before and in the next version an image with possible the error message gets another retry/load attempt before it is replaced by the custom error message.
I may also let the member disable the "live" custom image error icons, that might help in some situations.
FYI: The actual message "image not found" is given internally by your browser the the forum JS code (which in turn replaces the broken image icon with our own), so it is not just us who is saying it might not be there, but the actual browser you use is the one that gets it wrong.
I'll keep on working with these issues.
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
LonelyBoy
Gallery: 84 photos
Joined Oct 2014
Feb 17, 2017 16:29 |  #3
Pekka wrote in post #18276826 (external link)
Oh, hmm. Thanks for the response! I'm on Edge, but this is the only site that I get this issue on, so I figured it was a site issue. Of course, there are more and bigger images here than most places I go, so that might have something to with it also.
tonylong
...winded
Gallery: 60 photos
Feb 18, 2017 15:43 |  #4
the most common "spot where I have encountered this (at least for my images) has been where/when an image has for whatever been "removed" from access, typically in the Web host that I use sometimes because if I may have fallen behind in my subscription/payment to that Web host, and at times they have disabled posting to the image, specifically to the "original" copy of that image, although they do keep the various copies of my stuff long-term, but I can't post to the original full-size version. When that does pop up, well, I have to double-check my source and ensure that at least I can post to a "smaller version", rather than my full-sized original.
Anyway, that can explain why sometimes there can be a real issue with forum/Web access to stuff!
Tony
Pekka
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Feb 18, 2017 15:57 |  #5
LonelyBoy wrote in post #18276852 (external link)
I have updated the server software version (several bugs fixed and features added). Do you see any difference?
Later I'll make the site use SSL which also means new methods of communication with the browsers (HTTP/2). Let's see how it goes then.
LonelyBoy
Gallery: 84 photos
Joined Oct 2014
Feb 18, 2017 16:30 |  #6
Pekka wrote in post #18277747 (external link)
Let me see - it's inconsistent, which makes it the most frustrating sort of bug to track down. I'll surf for a bit and let you know if it appears different.
LonelyBoy
Gallery: 84 photos
Joined Oct 2014
Feb 18, 2017 17:17 |  #7
So it seems less common than it was, but it still happens, and on some of the image threads it still happens fairly frequently.
I also checked and it's only Edge - not Chrome, not Firefox. Haven't tried IE11 yet, but I can. This is also the only site it happens on, though.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Feb 18, 2017 22:35 |  #8
LonelyBoy wrote in post #18277801 (external link)
I still occasionally get that, like just a few minutes ago, with FFox which is what I usually use.
LonelyBoy
Gallery: 84 photos
Joined Oct 2014
Feb 19, 2017 04:09 |  #9
PhotosGuy wrote in post #18277994 (external link)
Thanks for letting me know I'm not the only one! I didn't spend extensive time checking the other browsers, but handy to know it's not just E.
rrblint
Gallery: 84 photos
Joined May 2012
Feb 19, 2017 09:55 |  #10
Often, if you reload the page(f5) the missing images will appear.
Mark
BigCol
Gallery: 67 photos
Mar 30, 2017 04:38 |  #11
I'm finding no difference in the occurrence of this issue. It is still happening very frequently.
Col
Levina ­ de ­ Ruijter
I'm a bloody goody two-shoes!
Gallery: 457 photos
Best ofs: 12
Mar 30, 2017 05:46 |  #12
When I've had an image unable to load in FF, it's always from photobucket. They do load fine in Safari though.
Wild Birds of Europe: https://photography-on-the.net …showthread.php?​p=19371752
Please QUOTE the comment to which you are responding!
saea501
... spilled over a little on the panties
Gallery: 43 photos
Mar 30, 2017 06:47 |  #13
BigCol wrote in post #18314664 (external link)
The forum in general for the past two days has been quirky. Images loading halfway or not at all but with no 'image failed to load' message. Sometimes when they do load it looks like a dial up connection....that is you can watch the image load in a scrolling fashion from top to bottom. Pages sometimes won't turn. I notice these problems only on this site. Others have been fine.
Seems better today.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
OhLook
Gallery: 105 photos
Joined Dec 2012
Mar 30, 2017 10:27 as a reply to  @ saea501's post |  #14
I haven't noticed an increase in failures during the past two days. Some images are marked as too large to load, as always. Maybe a little more slowness, but I can't be sure it isn't at my end, extra traffic on the ISP's lines or something. I use Firefox.
PRONOUN ADVISORY: OhLook is a she. | Comments welcome
Progress toward a new forum being developed by POTN members:
https://photography-on-the.net …/showthread.php​?t=1531051
PhotosGuy
Joined Feb 2004
Mar 30, 2017 11:33 |  #15
FFox: What I find interesting is that some images on a page load & some do not. Reloading the page brings them all up. This doesn't make sense to me, but I'm getting used to it.
2,921 views & 0 likes for this thread, 9 members have posted to it and it is followed by 5 members.
1465 guests, 129 members online
