Can you tell me what version lens this is by the 10 digit code?
70-200mm f2.8............ V1 or V2?
0120003133
I will try the EXIF info when I get home.
reefvilla Goldmember More info Post edited over 6 years ago by reefvilla. (3 edits in all) | Feb 24, 2017 13:25 | #1 Can you tell me what version lens this is by the 10 digit code? -----------Canon EOS R -----------
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Feb 24, 2017 14:09 | #2 Permanent banDid you try looking at the lens? Version II of the IS lens will say "II" right on it. If not, it is version one. If it doesn't say "Image Stabilized", there are no 'versions'. Canon only made one of the non-IS type.
Feb 24, 2017 15:11 | #3 Bassat wrote in post #18284010 Did you try looking at the lens? Version II of the IS lens will say "II" right on it. If not, it is version one. If it doesn't say "Image Stabilized", there are no 'versions'. Canon only made one of the non-IS type. It is rubbed off in that area. -----------Canon EOS R -----------
joeseph "smells like turd" More info | Feb 24, 2017 15:47 | #4 Doesn't help with the 10 digit code, but the 70-200mm F/2.8 IS MK I focusing ring rubber is the same width as the zoom ring width (about 32mm/ 1 1/4") some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Feb 24, 2017 15:52 | #5 Permanent banJoeseph is right. There is a photo of them side by side on this page:
NullMember Goldmember 3,019 posts Likes: 1130 Joined Nov 2009 More info | Feb 24, 2017 15:52 | #6 Permanentlyreefvilla wrote in post #18283965 Can you tell me what version lens this is by the 10 digit code? 70-200mm f2.8............ V1 or V2? 0120003133 I will try the EXIF info when I get home.
msowsun "approx 8mm" More info | Feb 25, 2017 01:50 | #7 If you show us some photos of the lens, we should be able to identify for you. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Sir_Loin Senior Member More info | Feb 25, 2017 05:53 | #8 The MkI IS version didn't use the 10 digit serial number as far as I'm aware so that should narrow it down. Look to see if there's an alpha numeric code printed on or near the rear lens mount as well, that's the old date code which will tell us the year of manufacture. I hope this helps. EOS 1D4, 5D3, EF 24-70mm f/2.8L II, EF 70-200mm f/2.8L II IS, EF 50mm f/1.8 STM, EF 85mm f/1.2L II * EOS R6, RF 24-105mm f/4.0-7.1 * EOS M5, EF-M 11-22mm f/4.0-5.6 IS, EF-M 18-55mm f/3.5-5.6 IS, EF-M 55-200mm f/4.5-6.3 IS, EF-M 22mm f/2.0, EF-M 28mm f/3.5 Macro IS * FL-F 300mm f/5.6 FLUORITE, FD 55mm f/1.2 ASPHERICAL, FD 24-35mm f/3.5L, FD 50mm f/1.2L, FD 300mm f/2.8L, FD 50-300mm f/4.5L
Feb 25, 2017 11:46 | #9 Sir_Loin wrote in post #18284533 The MkI IS version didn't use the 10 digit serial number as far as I'm aware so that should narrow it down. Look to see if there's an alpha numeric code printed on or near the rear lens mount as well, that's the old date code which will tell us the year of manufacture. I hope this helps. There is not -----------Canon EOS R -----------
Feb 25, 2017 11:48 | #10 The focus and zoom rings are about the same size as well so that helps me!! -----------Canon EOS R -----------
msowsun "approx 8mm" More info Post edited over 6 years ago by msowsun. (2 edits in all) | Feb 25, 2017 19:25 | #11 reefvilla wrote in post #18284740 The focus and zoom rings are about the same size as well so that helps me!! Thanks everyone! If the focus ring and zoom ring are the same size, and it has a 10 digit serial number with no date code on the rear mount, you have a 70-200mm f/2.8 without image stabilization. As Bassat said, there is only one version of this lens so it would not show "I" or "II". (Canon has never used "I" on any first version of any lens) Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member is semonsters 1522 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
