Thread started 24 Feb 2017 (Friday) 14:20
600EX RT /ST-E3-RT 1D MK IV
DarenM
Feb 24, 2017 14:20 |  #1
It appears that high speed sync is not available for with the 1D MK IV with radio transmission between these two units. I know that the 600EX can also be set for infrared mode. Is high speed sync available in this mode ? confused by all the various publications and posts
Canon 1D MK IV, Canon 1D MK III, Canon 5D, 24-70 2.8L, 70-200 2.8 L IS MK II, 17-40 F4 Canon, 430 EX, Canon A2E, 530EX Canon 1.4 Extender, 580 II, 600EX-RT, ST-E3-RT, (Way too much stuff for an amateur)
OceanRipple*
Joined Dec 2014
Post edited over 6 years ago by OceanRipple*.
Feb 24, 2017 14:28 |  #2
DarenM wrote in post #18284020 (external link)
Canon Wireless Light/IR type can offer HSS, certainly from a Canon 5xxEx and I presume, from a 600Ex-RT.
DarenM
Feb 24, 2017 14:39 as a reply to  @ OceanRipple*'s post |  #3
I guess i am wondering how or if the ST-E3-RT comes into play. Does that operate in IR as well?
OceanRipple*
Joined Dec 2014
Feb 24, 2017 15:04 |  #4
DarenM wrote in post #18284034 (external link)
Hi, (I'm not an RT guy) The Canon ST-E3-RT does not do Optical (Light/IR type) at all.
But I believe the 600ExRT can behave like a 580ExII as an Optical Canon Wireless 'Master' - doing so, the 580ExII can control & trigger under HSS.
Nortonski
Joined Oct 2013
Post edited over 6 years ago by Nortonski. (2 edits in all)
Feb 24, 2017 17:59 |  #5
See the LINK (external link) Canon state that HSS (using the ST-E3) only works on bodies from 2012, it does not work on older bodies like the 1DIV.
I have used it on both my old 5D3 & now the new 5D4 bodies without issue.
EDIT: whilst the ST-E3 doesn't offer Optical, the YN-E3 does...(I only have the ST, so haven't tested the YN)
Canon EOS 5D4
EF 17-40L | EF 24L II | EF 50L | EF 85L II | EF 24-70L 2.8 II | EF 70-200L 2.8 IS | EF 50M | EF 28-135 | 600EX-RT | ST-E3-RT
Nick5
Feb 25, 2017 11:16 |  #6
Nortonski wrote in post #18284223 (external link)
As an early investor of the 600 EX-RT ST-E3 RT System, three stated Scenerios of pre 2012 cameras have been listed.
However two have been shown and have worked in my 7D Version 1.
Sync Speed, one stop less than Camera Sync. False, camera worked just fine at 1/250.
High Speed Sync. False. While indicator Warning appeared on ST-E3 RT transmitter, images are recorded just fine past SyncSpeed.
GROUP Mode, True, does not work.
Group Mode is one of the luxuries of investing in the 5D Mark III in 2013.
You may want to do the Human Test on your Mark IV.
I just pulled out the 7D a few minutes back to prove what we found in 2012.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
DarenM
Feb 26, 2017 09:31 as a reply to  @ Nick5's post |  #7
Thank you. I will do that
2,134 views & 0 likes for this thread, 4 members have posted to it and it is followed by 2 members.
1549 guests, 135 members online
