Thread started 25 Feb 2017 (Saturday) 10:46
5DSR and 400mm f4 DO IQ?
Josh13
Feb 25, 2017 10:46 |  #1
Some back story I recently sold my 6D and am looking to get a 5DSR or 5d IV. I haven't seen any mention of the 5DSR and the first version of the 400mm f4 DO anywhere on the internet. The DO is awesome on my 7D and produced impressive results on the 6D. The DO however never really impresses me on the A7R, my thinking is maybe it's the extra resolution or maybe be just the quirky Metabones adapter. I Know the 5d IV is getting really close to the A7R resolution wise.
Does anyone have any thoughts about using the 5DSR and the 400mm f4 DO?
5DIV, Elan 7n, 400 f4 DO I, 100-400mm II, 1.4x TCIII, Tokina 16-28 F2.8, Tokina 12-28 f4, 85 f1.8, 50 f1.8 STM, Flashpoint 620m, YN14EX.
A7rIII, A6300, 100-400 GM, 85 f1.4 GM, 90 Macro, 55 f1.8, 16-35 F4, 35 f2.8, Batis 25 f2, Samyang 14 f2.8 AF, MC-11.
D500, 200-500, Tokina 300 f2.8, 35 f1.8
S110, D20, Hero 6, 3+
yellowt2
Joined Sep 2009
Feb 27, 2017 14:55 |  #2
Where in the frame does the A7R image not impress you? The pixel pitch of the 7D is smaller than the A7R, so the center of the image on the A7R should look as sharp as the 7D image (assuming it's in focus). You think the 6D images look better than the A7R; is this only when pixel peeping at 100% resolution, or when viewing a full image at the same size?
Depending on what you're seeing I see two possible explanations:
1. The lens is sharp in the center and slightly soft at the edges. When using the 7D you're looking at a crop of the center, so everything looks good. The 6D is lower resolution, so the edge softness gets hidden to some degree and you don't notice it. The A7R is high enough resolution that when you pixel-peep you see the edge softness. If you view the 6D and A7R full images at the same size they should look similar.
2. Issue specific to the A7R - either the A7R images are not completely in focus, or the adapter/lens mount has a little bit of tilt (this wouldn't surprise me with how heavy that lens is). The A7R doesn't have the best autofocus, especially with an adapter; it's possible the images just are not in the best focus.
If your problem is #1, then the 5DIV or especially 5DSR will show similar issues to what you're seeing on the A7R. If you problem is #2 then the 5D images should look a lot better.
1,090 views & 0 likes for this thread
Latest registered member is Apo1980
1116 guests, 356 members online
