Thread started 07 Mar 2017 (Tuesday) 07:45
30D will not fire
Chappy
Mar 07, 2017 07:45 |  #1
Hi,
I often buy and resell cameras and I have a 30D with a 17-85 IS lens that's very temperamental. It focuses on things and the green dot stops blinking but when you push the button down it won't fire. Then I got it to take 2 pics, then it went back to refusing to fire.
I formatted the 2 GB CF card, I reset the settings to factory default.
Then I raised the flash to test that and it will not fire again. I put a Canon 50mm 1.8 lens on it and that will not fire either.
What is the matter with it? I've had many Canon dSLRs that were moody like this. This one seems worse.
Olympus OM-D E M5 / Olympus Pen E PL1 / Olympus E-510
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 07, 2017 08:45 |  #2
I don't have a clue, but wonder if it will fire if the lens was put on manual focus? Maybe clean the contacts?
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Mar 07, 2017 13:13 |  #3
I'm guessing the shutter button switch contacts are suspect. Seems to be common, all you can do is either a DIY immersion in cleaning fluid or send it off to Canon to get the switch replaced.
If you have a remote cord for the camera you can confirm it's the on-board switch that is failing.
TF posting: here :-)
Chappy
Mar 07, 2017 14:30 |  #4
joeseph wrote in post #18294459 (external link)
That's exactly what it is. I had a Canon remote cable on my desk and hooked up to it and it fires every time with that.
Thank you.
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Mar 08, 2017 01:56 |  #5
no worries, it's only a $10 part (well, $8.12 (external link) ) but it is soldered onto a ribbon assembly, so would probably take a tech less than an hour to replace. If it were me, I'd do it myself but I have done board-level repairs before.
The DIY isopropyl fix I'd be wary of, as you'd have no control over where the liquid is going...
link to a DIY video here (external link)
Chappy
Mar 11, 2017 21:56 |  #6
I sent the 30D body back to the seller.
Thank you.
tmwhitm
Apr 18, 2017 19:20 |  #7
I have a 30D and had the exact issue. I performed the isopropyl alcohol DIY and it worked fine for me. You just have to ensure you don't pour too much through the battery compartment and have the camera tilted properly so it only runs through the shutter button. It has been a while since I performed this so I would definitely watch the video to make sure you are doing it properly...
Canon 30D | Canon 7D | Canon R6 |Sony α6000 / ILCE-6000 | Sony E 3.5-5.6/PZ 16-50 OSS | Sigma DC 17-70mm | Canon EF 70-200mm f/2.8L USM | Canon EF 70-200mm f/2.8L IS II USM |Canon EF24-105mm f/4L IS USM | Canon RF 50mm f/1.8 STM
2,624 views & 3 likes for this thread, 4 members have posted to it and it is followed by 2 members.
30D will not fire
897 guests, 120 members online
