This post maybe useful to those of us that own manual Tamron lenses and would like to extend their focal reach. I have the following lenses:
1. Tamron SP 35-80mm 1: 2.8-3.8
2. Tamron SP 35-210mm 1: 3.5-4.2
3. Tamron 80-250 mm 1: 3.8-4.5
4. Tamron SP 60-300mm 1: 3.8-5.4
I do not use them all as they cover each others focal length, it is mainly 1 and 4.
I have attached these lenses to a Canon 550D via a Adaptall 2 OM fitting with a OM to EOS adaptor with focus confirm chip between lens and camera.
All 4 lenses give the focus confirm beep at the widest aperture.
To give it a try I bought an after market Adaptall 2 EOS mount. I believe the original Adaptall 2 mounts to Canon EF are very rare and impossible to buy second hand.
From my test results on a very sunny day the after market Adaptall 2 EOS mount gave focus confirm beep the same as the Adaptall 2 OM wide open.
To continue with further tests I connected my Teleplus C-AF 1.4x Teleplus MC4 EF mount.
I connected the 4 above lenses to the Adaptall 2 EOS mount then to the Teleplus C-AF then to the Canon 550D but could not get any focus confirm beep.
Then followed the above 4 lenses with Adaptall 2 OM connected to the Teleplus C-AF via a OM to EOS adaptor with focus confirm chip, then the Teleplus to the Canon 550D and I found focus confirm beep with all 4 lenses.
In conclusion it appears that buying the after market Adaptall 2 EOS mount has been a waste of money if one wants the option of extending the reach of lenses. The original Adaptall 2 OM did the job with more options. From my experiences so far I have found Teleconverters or Teleplus lenses work very haphazardly with lenses and cameras.
