Have you found the need for 1/8000 sync speed very often when using strobe with hss?
Considering the Nikon D750 or D810 combining with the Cheetah Cl-600x for outdoor portrait use. Would I regret not having 1/8000?
silvermesa1 Member 145 posts Likes: 17 Joined Aug 2013 Location: Columbia, Mo. USA More info | Mar 11, 2017 18:53 | #1 Have you found the need for 1/8000 sync speed very often when using strobe with hss?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 11, 2017 19:19 | #2 Let us first consider some generally true characteristics of HSS flash...
So if X-sync is 1/200 and non-HSS flash is GN160, going to 1/250 is HSS GN80 going to 1/1000 is HSS GN40 going to 1/4000 is HSS GN20 and at f/4 the HSS flash is only good for 5' It is left to the student to do the arithmetic for the GN of the flash in question. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
LeftHandedBrisket Combating camera shame since 1977... More info Post edited over 6 years ago by Left Handed Brisket. | Mar 11, 2017 19:45 | #3 silvermesa1 wrote in post #18298394 Have you found the need for 1/8000 sync speed very often when using strobe with hss? Considering the Nikon D750 or D810 combining with the Cheetah Cl-600x for outdoor portrait use. Would I regret not having 1/8000? If I'm understanding you, the question is about cameras, not your flash. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
Mar 11, 2017 20:08 | #4 Well, it is about how fast your aperture you wanna set and how bright or dark is the ambient light you wanna capture.
nixland Senior Member More info Post edited over 6 years ago by nixland. (2 edits in all) | Mar 11, 2017 20:13 | #5 Off course we can also add ND filter to lower down your ambient light and slower down shutter speed.
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info Post edited over 6 years ago by bobbyz. | Mar 11, 2017 21:29 | #6 You can always use ISO50 if needed. I typically use f2 so I think 1/4000 is good enough. 1/8000 is nice to have but not the end of the world either. Fuji XT-1, 18-55mm
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info Post edited over 6 years ago by bobbyz. | Mar 11, 2017 21:33 | #7 Before HSS, I used to use ND filter but lot of times, nothing at all. Here using no ND filter to let the bg blow out. 1/4000 would have been more than enough here. Fuji XT-1, 18-55mm
ImageMaker... looks like I picked a bad week to give up halucinagens More info | Mar 11, 2017 23:43 | #8 silvermesa1 wrote in post #18298394 Have you found the need for 1/8000 sync speed very often when using strobe with hss? Considering the Nikon D750 or D810 combining with the Cheetah Cl-600x for outdoor portrait use. Would I regret not having 1/8000? I don't think so. One stop... I use Elinchrom (HS) and end up at 1/5000 often. It really depends on lighting conditions and your desired results. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
dmward Cream of the Crop More info | Mar 12, 2017 09:08 | #9 silvermesa1 wrote in post #18298394 Have you found the need for 1/8000 sync speed very often when using strobe with hss? Considering the Nikon D750 or D810 combining with the Cheetah Cl-600x for outdoor portrait use. Would I regret not having 1/8000? Since HSS turns the flash into a constant light source the difference between 1/4000 and 1/8000 shutter speed is determined by the ambient light. The other two ways to get the 1 EV is with ISO, down to 50 from 100, which with some cameras is an imperfect option. Or, stopping down the lens which may significantly change the visual character of the image. David | Sharing my Insights, Knowledge & Experience
MalVeauX "Looks rough and well used" More info Post edited over 6 years ago by MalVeauX. (2 edits in all) | Mar 12, 2017 10:36 | #10 Heya, 1/2000, F2.8, evening sun with HSSIMAGE LINK: https://flic.kr/p/QyhK27 1/500s, F3.5, evening sun with HSSIMAGE LINK: https://flic.kr/p/RiLmnp Very best,
| Latest registered member is Monkeytoes 1322 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
