I'm considering getting a Canon 7D MKII body. I currently use Lightroom version 5.7. Will this version of Lightroom recognize files from the 7D2? Thanks.
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info | Mar 13, 2017 23:22 | #1 I'm considering getting a Canon 7D MKII body. I currently use Lightroom version 5.7. Will this version of Lightroom recognize files from the 7D2? Thanks. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 6 years ago by Wilt. | Mar 13, 2017 23:26 | #2 Yes, according to Adobe web site. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
110yd Senior Member 790 posts Likes: 35 Joined Jan 2005 More info | Mar 13, 2017 23:29 | #3 Here is the story from Adobe
lowrider Goldmember 1,048 posts Likes: 291 Joined Aug 2008 Location: Tucson More info | Mar 14, 2017 00:40 | #4 I use PS CS6 and yes, Adobe Bridge recognizes my 7D MK II without incident.
Snydremark my very own Lightrules moment More info | Mar 14, 2017 01:13 | #5 Yes, it works just fine w/ the 7DII - Eric S.: My Birds/Wildlife
Mar 14, 2017 19:14 | #6 Thanks all for the replies. Going forward if I didn't have the latest version of Lightroom could I copy the raw files into Lightroom as DNG files? I went to the Adobe training site and they explained the benefit of dng files but didn't clarify if you still need the latest Lightroom version to coincide with the camera to properly convert to dng. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Mar 14, 2017 20:57 | #7 Permanent bancristphoto wrote in post #18301157 Thanks all for the replies. Going forward if I didn't have the latest version of Lightroom could I copy the raw files into Lightroom as DNG files? I went to the Adobe training site and they explained the benefit of dng files but didn't clarify if you still need the latest Lightroom version to coincide with the camera to properly convert to dng. Once you convert to DNG, any version should be able to open your raws. You may want to check this out:
Mar 15, 2017 08:02 | #8 Bassat wrote in post #18301231 Once you convert to DNG, any version should be able to open your raws. You may want to check this out: https://photography-on-the.net …/showthread.php?t=1472058 Thanks for the thread. I have such a smooth workflow now (insert card, Lightroom open automatically, sees photos, I click import, all done). I tried the "copy to DNG" tab at top of page and it works fine with my present camera that Lightroom recognizes. So going forward if I can't get your program to work I simply convert to DNG first then manually open Lightroom and import. Sort of like going to Canon's DPP program, batch converting to TIFF files and then importing to Lightroom. I tried that a while back but the 16 bit TIFF's were huge compared to raw files. The DNG files are a bit smaller than the raw so every little bit helps. Again, thanks for the help. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 15, 2017 08:58 | #9 One warning on Adobe's DNG converter, you must ensure that you convert to the correct Process Version and/or LR/ACR version to match you software. This is probably not such an issue if you are only going back one generatiion of software, but if you are using older versions especially CS2 which Adobe have mmade a free download, you will need to check you are exporting to the correct flavour of DNG.
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Mar 15, 2017 17:46 | #10 Permanent banBigAl007 wrote in post #18301520 One warning on Adobe's DNG converter, you must ensure that you convert to the correct Process Version and/or LR/ACR version to match you software. This is probably not such an issue if you are only going back one generatiion of software, but if you are using older versions especially CS2 which Adobe have mmade a free download, you will need to check you are exporting to the correct flavour of DNG. ... Alan Thanks for that, Alan. I was unaware.
| Latest registered member is semonsters 1154 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
