Thread started 18 Mar 2017 (Saturday) 07:31
Calling all long exposure people!
mamaof2
Gallery: 10 photos
Joined May 2014
Post edited over 6 years ago by mamaof2. (2 edits in all)
Mar 18, 2017 07:31 |  #1
I am trying to tackle long exposure and it is kicking my butt! I went out and messed around and well came back with pics that need to be trashed. :-P. What are some tips in making LE pictures turn out? Thanks!!
There are going to be a lot of "why in the world did you do xyz" ha! IDK why I did that is why I am asking you :)
IMAGE: https://c1.staticflickr.com/3/2903/32655344744_13d51062cd_z.jpg
IMAGE LINK: https://flic.kr/p/RKDb​if  (external link) LE5 3-2017 (1 of 1) (external link) by Jessi mamaoftwo (external link), on Flickr
IMAGE: https://c1.staticflickr.com/4/3850/32655347374_c4d6139dc0_z.jpg
IMAGE LINK: https://flic.kr/p/RKDc​5A  (external link) LE4 3-2017 (1 of 1) (external link) by Jessi mamaoftwo (external link), on Flickr
IMAGE: https://c1.staticflickr.com/3/2846/33498991685_c274573c59_z.jpg
IMAGE LINK: https://flic.kr/p/T3c6​9a  (external link) LE3 3-2017 (1 of 1) (external link) by Jessi mamaoftwo (external link), on Flickr
Jessi
T4i/Nifty fifty/ 18-55/ DCR 250 macro attachment/ 55-250 stm/ Few old film lenses
chauncey
Mar 18, 2017 07:39 |  #2
I fail to see anything wrong with the long exposure aspect of your image.
There are other problems...such as DOF. Your near stones are OOF...why?
mamaof2
Gallery: 10 photos
Joined May 2014
Mar 18, 2017 07:47 |  #3
chauncey wrote in post #18304049 (external link)
IDK why it is OOF? When I did the test shot...AV,F11,set focal point, changed to Manual, put filter on, took picture. I read to do it that way.
Jessi
-Duck-
my head is usually in the way
Gallery: 19 photos
Joined Apr 2016
Mar 18, 2017 09:02 |  #4
Jessi, Like Chauncy, I also don't see anything wrong with your exposure in the first image. There are other issues with the image that make it a less desireable image. Like a lack of an interesting subject and high contrast between your lights and darks, but that may not have been the reason for this image (I can assume since you are trying out a new technique).
Long exposures in art photography are typically done to play with the effect of time, as you show here. Unlike conventional images, that aspect plays a strong part in the composition but is never the main subject. You still need a strong composition to your image. That may be one reason why you are unsatisfied with your images.
Then there is the technical aspect of the technique. Choosing the right time of day (or night) is still important to making a great image. High contrast shadows on a subject is hardly ever appealing, no matter what shooting technique you are using. Long exposure techniques won't solve that problem and likely exacerbates the problem.
As for the DoF issue, that is a result of basic light physics. When dealing with apertures, we know that the larger the opening the more light comes in at once. The more light the more scatter resulting in more blur outside the focal field. In long exposures, even with a closed up aperture, the fact that the shutter is open longer will allow the sensor to capture more of the light scatter than in a regular exposure. This will result in a slight (depending on length of time) shift of DoF.
Two obvious solution to your issue above is to pick a time of day where the exposure range is within your camera's ability and then pick a subject matter/composition that will make people say, "wow". Once you have that, adding a long exposure will make for a truly stunning image.
Just my two bits. Best of luck.
"If you didn't learn something new today, you wasted a day."
Unitas Photography (external link)Facebook (external link)
NullMember
Mar 18, 2017 09:35 |  #5
bannedPermanently
mamaof2 wrote in post #18304057 (external link)
But the three images that you have posted were all shot at f5.6
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Post edited over 6 years ago by Scrumhalf.
Mar 18, 2017 10:21 |  #6
https://photography-on-the.net/forum/showthre​ad.php
You may want to start 1 thread to ask your questions. Otherwise, the discussions kinda get bifurcated.
As I mentioned in your other thread, you need to shoot with a smaller aperture and a shorter FL or both. If 55mm is your shortest FL, then you need to step way back. If you want things that are just a few feet from you, as well as things that are say several hundred feet away from you, or even up to the horizon, to be in focus, you'll need a wide angle lens or go to F/18 or something like that. This is where a DOF calculator comes in handy.
And a wide angle lens. There is a 10-18 STM on sale at the Canon refurb sale for 200 bucks. It's a very good lens and of you like landscapes, I would strongly urge you to pick one up.
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Mar 18, 2017 10:58 |  #7
-Duck- wrote in post #18304117 (external link)
Then there is the technical aspect of the technique. Choosing the right time of day (or night) is still important to making a great image. High contrast shadows on a subject is hardly ever appealing, no matter what shooting technique you are using. Long exposure techniques won't solve that problem and likely exacerbates the problem...
Very early in the morning, & very late in the evening will help to solve your contrast problem, + the colors of the light will be more interesting. (But not so much in B&W.)
DreDaze
Gallery: 49 photos
Mar 18, 2017 11:00 |  #8
I feel like the typical uses for long exposure are to show motion, or to sometimes flatten out rough water...but i think the shot without long exposure needs to be interesting before adding the filter...this looks like just a shot of a couple rocks...
Andre or Dre
gear list
Instagram (external link)
Alveric
Gallery: 38 photos
Post edited over 6 years ago by Alveric.
Mar 18, 2017 11:51 |  #9
john crossley wrote in post #18304142 (external link)
Forget about AV: Manual in perpetuity.
The camera was probably left set to f/5.6 in manual mode, and used that when you switched from the semi-auto mode. Values set in different modes do not carry over to others.
Focus a third of the way into the frame and you should be OK. Even better, use f/16: the diffraction monster only goes after the pixel peepers. And using a smaller aperture will add to your exposure time, which in this case is what you want.
*Do not go to f/22, however. Diffraction does shew even to normal viewers at such aperture.
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Mar 18, 2017 11:55 |  #10
My recommendation is to put the long expsosure stuff on the shelf for a bit. Play around with your aperture, FL and focusing distance and figure out how to get all your points of interest in focus, from the closest object of interest to the farthest. One tip - if you have to choose, get the closest object in focus, even if that means the distant stuff isn't (ideally, both will be in focus of course). The eye is drawn to OOF objects close in, but tends to ignore OOF objects far away.
Once you get the regular exposure shots down pat, then add the long exposure element.
Sam
mamaof2
Gallery: 10 photos
Joined May 2014
Mar 18, 2017 17:35 |  #11
DreDaze wrote in post #18304199 (external link)
I went out just to mess around with LE, I know it is not an exciting picture but it was just to play around with. This also was moving/splashing water..it was located on the Mississippi River.
Jessi
mamaof2
Gallery: 10 photos
Joined May 2014
Mar 18, 2017 17:35 |  #12
I want to thank you all for taking the time to post! I am reading through them all and will learn from each of you. Thanks again!
Jessi
2,540 views & 0 likes for this thread, 8 members have posted to it and it is followed by 4 members.
1090 guests, 119 members online
