Hi all,
Is it possible to have an on camera flash to be bounced on ettl and a flash OOC on manual at the same time? I own a 5d3, 1x yn622, 2x yn685 and 1x canon 430
Sorry for the noob question
cubatahavana I still don't see it More info | Mar 21, 2017 15:15 | #1 |
dmward Cream of the Crop More info | Mar 21, 2017 15:18 | #2 cubatahavana wrote in post #18307117 Hi all, Is it possible to have an on camera flash to be bounced on ettl and a flash OOC on manual at the same time? I own a 5d3, 1x yn622, 2x yn685 and 1x canon 430 Sorry for the noob question I used to do it all the time. David | Sharing my Insights, Knowledge & Experience
Mar 21, 2017 15:20 | #3 dmward wrote in post #18307123 I used to do it all the time. Using the yn622 on camera may complicate things a bit, but if you can get groups setup with the speedlite on top of the yn622 set to TTL, then its a simple matter using the camera flash menu to set the remote speedlites to M mode. If you don't have all the speedlites on yn622 transceivers it may be a bit more challenging. Ok, so, 5d3 + 622c + canon speedlight on top ETTL and rest on manual? My Flickr
Mar 21, 2017 16:00 | #4 cubatahavana wrote in post #18307126 Ok, so, 5d3 + 622c + canon speedlight on top ETTL and rest on manual? Just discovered the mix mode on the yn622. That's fantastic. I can have my 430 on top on ettl and then 1 or 2 speed lights bouncing from the corners in manual. Once my batteries are charged again, I will try a setup with 430 on ettl, and the 2 speed lights bouncing in two different groups, so I can get bounce light and back light for events with 2 different sources for the back light. For this light, better bounced or direct? I was thinking around 1/32 or 1/64 strength? My Flickr
| Latest registered member is semonsters 1035 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
