Does anybody use their 180mm macro lens for both macro work and telephoto work? If so, do you need two different autofocus micro adjustments? If so, what are those AFMA values you use at both ends? Is the calibration spread huge?
texshooter Senior Member 652 posts Likes: 26 Joined Jun 2009 More info | Apr 04, 2017 15:20 | #1 Does anybody use their 180mm macro lens for both macro work and telephoto work? If so, do you need two different autofocus micro adjustments? If so, what are those AFMA values you use at both ends? Is the calibration spread huge?
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info | Apr 04, 2017 22:57 | #2 The question about AFMA does not make sense. 1Dx, 5D2 and some lenses
notastockpikr Senior Member 440 posts Likes: 73 Joined Aug 2011 Location: Canada More info | Apr 05, 2017 07:06 | #3 Focus on the 180 is very slow and the lens is heavy. The lens is not a multi-purpose lens. It's designed for macro photography and makes a cumbersome telephoto lens. My 2 cents.
FEChariot Goldmember More info Post edited over 6 years ago by FEChariot. | Apr 05, 2017 08:49 | #4 CheshireCat wrote in post #18319790 The question about AFMA does not make sense. If one needs to use AFMA, then it means he/she has a defective camera. If you also have a defective camera, then the AFMA adjustment required by your camera will likely be different. It could be the camera or it could be the lens or it could be a combination of both. So not sure what you are saying. I have lenses needing Afma on my 7D but not my XT and vice versa well the XT doesn't have afma but it's soft. Personally if I need different afma values depending on subject distance then I send the lens back if it's within the exchange policy or I send it to canon for calibration Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
I think my Canon 180mm macro is defective. See below. Are the diverging track marks normal? Shouldn't the OOF areas be smooth instead of crooked? Image hosted by forum (848859) © texshooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info | That is perfectly normal. Your lens is ok. 1Dx, 5D2 and some lenses
vengence Goldmember 2,103 posts Likes: 108 Joined Mar 2013 More info | Apr 05, 2017 10:55 | #7 AFMA is used to correct for manufacturing tolerances. Your camera is not defective if you need to use it. That's why it's there in the first place. Every lens will benefit from AFMA assuming you can both measure it accurately and have a fine enough adjustment. The reality is there isn't a lot of difference between a +1 or a +2 and zero so most people won't notice if it's off a little. Most of the people who say a lens/camera combo doesn't need it could actually realize a small benefit from a small AFMA adjustment. It is difficult to measure with that much accuracy however without dedicated software like FoCal (which I highly recommend btw).
texshooter THREAD STARTER Senior Member 652 posts Likes: 26 Joined Jun 2009 More info Post edited over 6 years ago by texshooter. (2 edits in all) | Apr 05, 2017 11:02 | #8 CheshireCat wrote in post #18319790 The question about AFMA does not make sense. If one needs to use AFMA, then it means he/she has a defective camera. If you also have a defective camera, then the AFMA adjustment required by your camera will likely be different.
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info Post edited over 6 years ago by CheshireCat. (2 edits in all) | Apr 05, 2017 11:19 | #9 FEChariot wrote in post #18320036 It could be the camera or it could be the lens or it could be a combination of both. So not sure what you are saying. I have lenses needing Afma on my 7D but not my XT and vice versa well the XT doesn't have afma but it's soft. Well, then some piece of your equipment is defective. 1Dx, 5D2 and some lenses
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info Post edited over 6 years ago by CheshireCat. | Apr 05, 2017 11:36 | #10 vengence wrote in post #18320160 AFMA is used to correct for manufacturing tolerances. Your camera is not defective if you need to use it. That's why it's there in the first place. Every lens will benefit from AFMA assuming you can both measure it accurately and have a fine enough adjustment. The reality is there isn't a lot of difference between a +1 or a +2 and zero so most people won't notice if it's off a little. Most of the people who say a lens/camera combo doesn't need it could actually realize a small benefit from a small AFMA adjustment. It is difficult to measure with that much accuracy however without dedicated software like FoCal (which I highly recommend btw). Do you work at Canon ? 1Dx, 5D2 and some lenses
Apr 05, 2017 11:52 | #11 ksbal wrote in post #18320192 The photo you show is normal. One thing I learned the hard way was you need to watch what light you do your adjustment under. I tried to mfa my 50mm 1.4 under white florescent, not realizing that light made a difference... it was way off when using the lens in daylight or flash. So experiment with that, just in case you are doing macro photography under one light condition, and then taking portraits under another. JMHO YMMV. And you live like this? You speak as though this is normal. I can't imagine how a normal lens would require a different AFMA for daylight than any other light source. Perhaps imperceptible differences, but "way off" differences? Now I'm worried.
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info Post edited over 6 years ago by CheshireCat. (2 edits in all) | Apr 05, 2017 11:53 | #12 texshooter wrote in post #18320168 What I'm getting at is this. My 180mm lens requires a minimum of -8 AFMA because it severely back focuses when doing macro work Like I said, the typical AFMA for any lens is 0 (ZERO). 1Dx, 5D2 and some lenses
Archibald You must be quackers! More info | Apr 05, 2017 11:54 | #13 texshooter wrote in post #18320168 What I'm getting at is this. My 180mm lens requires a minimum of -8 AFMA because it severely back focuses when doing macro work. But that AFMA requirement drops as I shoot farther away. For example, when I shoot at 25 time the focal length (15ft), the lens requires a -6 AFMA (also, the sharpest aperature slides from f5.6 to f8, which I found strange). I haven't tested the lens at telephoto distances, say 50x or more, but wouldn't be surprised if the AFMA changes dramatically the farther away you stand from the subject. I think I'll just use it for macro work only. That's what it was designed for anyway. Then I don't have to worry about AFMA shifts. But would like to know what is typical for this lens so I don't worry about owning a bad copy (needing a -8 AFMA already make me uneasy). This lens hasn't been updated in over 20 years, so maybe I should expect flaws. There is practically no difference between -8 and -6. Even -8 is only around the DOF for the lens when the aperture is fully open, compared to no adjustment at all. So your lens is not "severely back focusing" based on what you say. But it might be slightly backfocusing. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Apr 05, 2017 12:07 | #14 Archibald wrote in post #18320229 Are you sure you are doing the adjustment correctly? Every time I do my lenses I end up with a different number. (Not greatly different, but different.) I'm using the Lens Align with Focus Tune. The proof is in the graph.... Image hosted by forum (848893) © texshooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
CheshireCat Goldmember 2,303 posts Likes: 407 Joined Oct 2008 Location: *** vanished *** More info | Apr 05, 2017 12:13 | #15 ksbal wrote in post #18320205 This seems to be a rather extreme take on mfa. I think there is always a compromise in mass production and qc of equipment before sale. I think mfa was put in responding to a need of photographers rather than because manufacturers are trying to lower quality control.. they are just letting an educated consumer have a tool that can help bring the tolerence between the camera and the lens into alignment. Lens Rentals has an excellent article on QC and lens production. Thanks for the link, very interesting, but it has more to do with lens optical performance rather than focusing errors. 1Dx, 5D2 and some lenses
| Latest registered member is semonsters 1034 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
