Quick, easy question (But I forgot the answer): Should polarizing filter be placed forward or behind a neutral density filter?
trailguy Senior Member More info | Apr 05, 2017 08:22 | #1 Quick, easy question (But I forgot the answer): Should polarizing filter be placed forward or behind a neutral density filter?
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 6 years ago by Wilt. | Apr 05, 2017 10:17 | #2 Optically it should not matter. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
birderman Goldmember 1,052 posts Likes: 44 Joined Mar 2011 Location: London, UK More info | Apr 05, 2017 10:33 | #3 With systems such a Nisi the polariser in the holder first and then the ND filter(s). Birderman
Snydremark my very own Lightrules moment More info | Apr 05, 2017 11:12 | #4 with regular NDs, I don't think it particularly matters. If you're using panel filters (LEE system, etc) and a high density ND, like the Big Stopper, it's best to put the ND in the slot closest to the lens in order to allow the foam gasket to do its job and minimize light leakage around the edges. - Eric S.: My Birds/Wildlife
kf095 Out buying Wheaties More info | Apr 05, 2017 12:35 | #5 I would prefer to have vND on the lens first and rotate it to get right exposure first. And after it rotate polarizing one. From my real use of two, I've had polarizing first and then holder on top of it for slide-in welding grade ND. I quit very quickly from it. M-E and ME blog
| Latest registered member is Niagara Wedding Photographer 1219 guests, 149 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
