Which canon body is best to use for macro photography: 60D, 70D or the new 77D?
I have the lenses, but only the 40D.
RonnyGeenen Member 125 posts Likes: 1 Joined Dec 2011 More info | Apr 11, 2017 15:25 | #1 Which canon body is best to use for macro photography: 60D, 70D or the new 77D?
BlakeC "Dad was a meat cutter" More info | Apr 11, 2017 15:32 | #2 77D Blake C
Apr 11, 2017 15:32 | #3 Do a search for Lord V in the Macro section, you will get advice from an expert Chris
MalVeauX "Looks rough and well used" More info | Apr 11, 2017 15:37 | #4 Stick to your 40D.
BlakeC "Dad was a meat cutter" More info Post edited over 6 years ago by BlakeC. | yea but which of those 3 is the best? Blake C
OK, I have one problem with the 40D. 3 inch view in the back is fixed. I am retired and have a hip problem which gives me problems to bend.
MalVeauX "Looks rough and well used" More info | Apr 11, 2017 16:15 | #7 Ronny Geenen wrote in post #18325356 OK, I have one problem with the 40D. 3 inch view in the back is fixed. I am retired and have a hip problem which gives me problems to bend. For the others, I have the 60mm and 100mm lens. So are you saying you're looking for an articulating Live View LCD and that's what you use to compose and shoot with at ground level?
CyberDyneSystems Admin (type T-2000) More info Post edited over 6 years ago by CyberDyneSystems. | Apr 11, 2017 16:22 | #8 Ronny Geenen wrote in post #18325356 OK, I have one problem with the 40D. 3 inch view in the back is fixed. I am retired and have a hip problem which gives me problems to bend. For the others, I have the 60mm and 100mm lens.
Good answer and thank you.
Warl0rd Goldmember 2,230 posts Likes: 153 Joined Aug 2008 Location: Portugal More info Post edited over 6 years ago by Warl0rd. | 77D has one of the smallest viewfinder on the market, so I would exclude it (unless you plan on using the screen only). Paulo
Archibald You must be quackers! More info | Apr 12, 2017 14:03 | #11 Warl0rd wrote in post #18326134 77D has one of the smallest viewfinder on the market, so I would exclude it (unless you plan on using the screen only). http://www.neocamera.com …iewfinder_sizes?sort=size Interesting less-familiar parameter to compare cameras. Canon R5 and R7, assorted Canon lenses, Sony RX100, Pentax Spotmatic F
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 6 years ago by Wilt. | Apr 13, 2017 01:10 | #12 CyberDyneSystems wrote in post #18325378 If coming from a 40D, I would suggest sticking with the XXD line, (70D or 80D) All your familiar controls will be there, plus a few more. You would be trading ergonomics at all. Stepping down to the 77D line though many parts upgraded, some controls will be unfamiliar.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Warl0rd Goldmember 2,230 posts Likes: 153 Joined Aug 2008 Location: Portugal More info | Apr 13, 2017 17:49 | #13 Archibald wrote in post #18326176 Interesting less-familiar parameter to compare cameras. I have the 7D2 and SL1, and the SL1 has a much smaller viewfinder according to neocamera, but I don't notice any difference when shooting. I still haven't done macro work with the 80D, but I did notice some differences between the 80D and 450D (same size as our SL1). Paulo
CyberDyneSystems Admin (type T-2000) More info | Apr 14, 2017 13:20 | #14 Wilt wrote in post #18326655 But Jake, you forget that Canon did indeed make the nnD more like the nnnD when it launched the 60D, getting rid of the joystick, and getting rid of the PC cord connector...it is now necessary to buy a 7Dn or 5Dn or 1Dn to keep both. Admittedly, for many it makes little difference. But for some it does make a significant difference. Actually, what I really forgot, was that the 77D does away with the hard to use Rebel multi-controller d-pad as found on the T7i and most all other rebels and adds in an XXD style wheel,. the likes of which I pretty much can not live without! GEAR LIST
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 14, 2017 13:56 | #15 Warl0rd wrote in post #18327244 I still haven't done macro work with the 80D, but I did notice some differences between the 80D and 450D (same size as our SL1). The 77D viewfinder is even smaller then your SL1 (which is "amazing" since your SL1 body is smaller then the 77D :P), perhaps canon thinks people are quiting the viewfinder and using DSLR like smartphones ![]() Let's keep everything in context though
So the 77D viewfinder is indeed a bit better than the T6 and the same as the T7i, yet very inferior to the T7 specs! Yet the T7 has inferior pixel count to the T7i. Canon yet again exhibits some real discombobulation in positioning products to confuse the buyer! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is Frankie Frankenberry 1379 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
