Heya,
Choosing a scope type will have a lot to do with your mount's limits, the camera sensor size (relating to FOV) and the subject matter.
A newtonian's strength is the potential speed of the focal ratio and the larger aperture for the least cost. The offset is that the focal length is not long and the size/weight is pretty enormous (they're proverbial wind sails when under-mounted), require correction options (adds to cost), etc. They can be great for imaging DSO and general visual use. They can be ok for planets, but only with larger apertures and expensive powermate barlows to get enough magnification to get some pixels on the subject. Pretty good for lunar, if the aperture is large enough, again, needing powermates to really get the magnification. The nice thing of the newt reflector is the inexpensive quick access to F4 optics with a decent focal length for DSO (such as a 6 inch F4 astrograph for about $299 new). Add correction ($150) optics. Much cheaper than a comparable refractor and SCT's can't get here for this cost.
A SCT is a long focal length slow focal-ratio instrument that is great for planets and lunar. They can be ok for DSO, but only with a very good setup and focal reduction and other adapters (like faststar, etc). Traditional SCT setups are not great for DSO without serious mounts, guiding and lots experience. SCT's are very easy to image with for planets and lunar though and that's where they really shine right away without anything special added. SCT's are compact and fairly easy to mount at 8 inches and under, but over that the weight goes up fast and the mount requirements go up with it. If you're into planets & lunar surface, an SCT is an ideal way to start. Also, SCT's can be cheap used, such as the C6 ($250), C8 ($450), C9.25 ($650) on the 2nd hand market, for what you get with them.
Refractors are a great do-all tool, ideal for short focal lengths and color correction and flat fields and wide FOV for large DSO. If you're into DSO, a refractor is the way to go. I recommend a refractor for everything short of planetary work honestly, as a starting point. Combine with a large sensor camera and the FOV is wide and you can tackle the big DSO's. Big refractors become extremely heavy and extremely costly quick. I'd stick to short refractors aimed at imaging, like an apochromatic with a focal length of 400~600mm and F6~F7.5 or so. You will want a flat field corrector and potentially a focal reducer. Used market is huge for these as they're commonly traded (the small ones).
I image with SCT & Refractor.
I also do a lot of ultra narrowband imaging (solar in hydrogen alpha) but I do this with refractors.
Very best,
