Thread started 13 Apr 2017 (Thursday) 22:40
What is needed to Trigger these flashes?
Nicole2320
Apr 13, 2017 22:40 |  #1
I am new to off camera flash, so I want to learn how to do. I have a Cheetah Light 360 and Wireless Transmitter and 430III-RT. What do I need or do I need a transmitter to trigger that 430 as the slave?
Nicole
Canon EOS 70D | Canon EF 85mm f/1.8 USM, EF-S 55-250mm f/4-5.6 IS STM, EF-S 18-55mm f/3.5-5.6 IS STM, EF 50mm f/1.8 STM | Canon Speedlite 430EX III-RT | Cheetah CL 360
OceanRipple*
Joined Dec 2014
Post edited over 6 years ago by OceanRipple*.
Apr 14, 2017 02:38 |  #2
Which 'Wireless transmitter' do you have, exactly?
(Your 430ExIII RT is also a 'wireless transmitter' (radio or light communications) - but it 'speaks' only 'Canon RT'.)
Nicole2320
Post edited over 6 years ago by Nicole2320.
Apr 14, 2017 06:08 as a reply to  @ OceanRipple*'s post |  #3
The cheetah transmitter, it came with the 360
Nicole
110yd
Joined Jan 2005
Apr 14, 2017 08:56 as a reply to  @ Nicole2320's post |  #4
Keeping it simple,
The answer is place a Cheetah Light X 2.4 G Wireless Receiver on the hotshoe
of your 430III-RT. The transmitter sits in the hotshoe of your camera. You will
be able to use the transmitter sitting in the hotshoe of your camera, or your
camera flash menu to control the two flashes.
Hope this helps,
110yd
Nicole2320
Apr 14, 2017 09:07 as a reply to  @ 110yd's post |  #5
Thank you, so i need to buy Cheetah Light X 2.4 G Wireless Receiver
Nicole
Nicole2320
Apr 14, 2017 10:29 as a reply to  @ 110yd's post |  #6
I can't wait on Cheetah shipping and don't want to psy $50 for two shipping. Are there wireless system that i can order from Amazon that will work with canon and cheetah?
Nicole
110yd
Joined Jan 2005
Post edited over 6 years ago by 110yd.
Apr 14, 2017 10:48 as a reply to  @ Nicole2320's post |  #7
You can also use the Flashpoint trigger from Adorama.
https://www.adorama.co​m/fprrr2rc.html (external link)
It is the same as Cheetahstand. Both made by Godox in China.
Edit---there are units on Amazon that are the same.
Regards,
110yd
Nicole2320
Apr 14, 2017 10:53 as a reply to  @ 110yd's post |  #8
Thank you Adorama is closed and won't ship till 21st even if purchased via Amazon. Any other suggestions?
Nicole
Nicole2320
Apr 14, 2017 11:37 |  #9
110yd wrote in post #18327776 (external link)
Regards,
110yd
Would these work with canon and cheetah CowboyStudio NPT-04 4 Channel Wireless Trigger for External Speelights with 1 Trigger and 2 Receivers (NPT-04+extra receiver)
Nicole
110yd
Joined Jan 2005
Apr 14, 2017 11:49 as a reply to  @ Nicole2320's post |  #10
That would not work WITH the Godox/Cheetahstand/Fla​shpoint. The radios for the Godox/Cheetahstand/Fla​shpoint are
not the same as the CowboyStudio radio. My suggestion is to stick with the radio in your Cheetah Light 360, and NOT mix things up.
I have been through multiple generations of radio triggers and have somewhat abandoned the older stuff and focused
on the radios in the newer Godox Flashes. I do not miss having to carry multiple spare double A batteries in my bag. Godox has
done a decent job of Xeroxing the Canon wireless system. If you have a newer Canon body, you can have up to 5 groups. On an
older body, you only get 3 groups.
Hope this helps,
110yd
Nicole2320
Apr 14, 2017 12:00 |  #11
110yd wrote in post #18327832 (external link)
Hope this helps,
110yd
Thanks i need a receiver for next Thursday and adorama and bh won't ship till after and cheetah can't guarantee unless 2 day delivery for $50. So I'm out of solutions?
Nicole
110yd
Joined Jan 2005
Apr 14, 2017 12:11 as a reply to  @ Nicole2320's post |  #12
If you want to use your Canon 430, a Godox X1R receiver would be the simple solution. You could pile on a YN-622c but now we are mixing
radios. My suggestion is to stick with the X1-R. Your timing is just a little off in dealing with a last minute purchase.
The Godox/Cheetahstand/Fla​shpoint solution just plain works....My suggestion is to stick with it, as opposed to band-aiding a work around.
Hope this helps,
110yd
NDAPhoto
Joined Jul 2015
Post edited over 6 years ago by NDAPhoto. (3 edits in all)
Apr 14, 2017 12:39 |  #13
Based on your other thread, if you own the Cheetah 360X and only plan to use the 430ex III as a background or hair light, you can buy the Adorama Flashpoint Zoom R2 (or Godox TT600) Manual flash for $69 instead. This flash has a built-in receiver already. It is not TTL so you set the power manually, but the advantage is you use the Godox/Cheetah system and don't need an additional receiver.
https://www.adorama.co​m …Nmc_N29pNMCFYFq​fgod-QoA1g (external link)
Nicole2320
Apr 14, 2017 15:31 |  #14
NDAPhoto wrote in post #18327863 (external link)
Thanks but I don't want to invest in another flash.
Nicole
dmward
Gallery: 29 photos
Post edited over 6 years ago by dmward.
Apr 16, 2017 08:32 |  #15
Nicole2320 wrote in post #18327839 (external link)
Go to Amazon, find the Godox Canon receiver and look for a seller that fulfills via Amazon. That means that the product will come from the Amazon warehouse. Depending on where you're located relative to the warehouse you may get it next day.
Like this: https://www.amazon.com …s=godox+x1+rece​iver+canon (external link)
11,996 views & 1 like for this thread, 7 members have posted to it and it is followed by 4 members.
1088 guests, 110 members online
