Thread started 18 Apr 2017 (Tuesday) 19:11
EOS 7D Av Shooting
tmwhitm
Apr 18, 2017 19:11 |  #1
This may be more of a sanity check for me to see if I am missing something. I have noticed that when I shoot with aperture priority my photos are coming out dark, even outdoors with full sun, ISO set to 200. To verify my aperture setting, I will set the camera to fully auto and then match the aperture setting in aperture priority. What I noticed was the camera was setting the shutter speed differently at fully auto than with aperture priority with the same setting. Would anyone know if I am missing something either with the configuration of the camera, the Av settings or maybe it's just the photographer...Thank you,
Canon 30D | Canon 7D | Canon R6 |Sony α6000 / ILCE-6000 | Sony E 3.5-5.6/PZ 16-50 OSS | Sigma DC 17-70mm | Canon EF 70-200mm f/2.8L USM | Canon EF 70-200mm f/2.8L IS II USM |Canon EF24-105mm f/4L IS USM | Canon RF 50mm f/1.8 STM
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Apr 18, 2017 19:40 |  #2
tmwhitm wrote in post #18331594 (external link)
Heya,
Check your +/- EC option. The little graph with the stops +/-. You either have EC turned negative, or you're using evaluative mode and shooting something with a very bright source within the FOV.
Very best,
tmwhitm
Apr 18, 2017 20:16 as a reply to  @ MalVeauX's post |  #3
Thanks but the camera was set to spot metering and the +- was in the middle. AF points are independent of the metering?
MalVeauX
Joined Feb 2013
Apr 18, 2017 20:17 |  #4
tmwhitm wrote in post #18331650 (external link)
In spot metering, it will meter the selected AF spot. Check which one it is.
Very best,
tmwhitm
Apr 18, 2017 20:26 as a reply to  @ MalVeauX's post |  #5
It wasn't the center, it was set to four points around the center. I use this for action shots. I will have to test. Thanks...
oldvultureface
Gallery: 85 photos
Apr 18, 2017 20:27 |  #6
With spot metering, the 7D uses the center circle in the viewfinder. Set evaluative or center weighted metering and see if exposures are better.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Apr 18, 2017 20:34 |  #7
What exactly are you shooting? If you are spot metering a subject in a white shirt, or a white bird or a white car then the meter will be fooled and will under expose (even though the meter says the exposure is correct). Does it still happen if you point the camera at a black wall?
Dan Marchant
tmwhitm
Apr 18, 2017 20:45 as a reply to  @ Dan Marchant's post |  #8
Outside portrait, Easter picture, very bright. I will have to test against a darker subject. Mentioned in the post above yours, I do recall now that I have played with the metering by changing it to evaluative and had better results but that was inside taking hockey photos. I just must have the wrong combination set, it's just that I don't recall having this issue with my 30D.
Wilt
Apr 18, 2017 20:47 |  #9
Green box mode and P mode both behave differently than Av...if ISO 400 were set and f/4 was the selected aperture in Av mode, it would behave more similar to P mode and Green Box mode.
P and GreenBox are simply programmed to try to keep the know-little snapshooter out of trouble for most situations, whereas Av mode assumes the user knows a little about what they are doing and the implications of a too-slow shutter speed.
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 6 years ago by mwsilver.
Apr 18, 2017 20:51 |  #10
tmwhitm wrote in post #18331657 (external link)
It's pretty obvious that your use of spot metering is the issue. Try evaluative instead. I'm curious why you decided to use spot metering for your action shots. Spot meters on the center 5% of the viewfinder and should mainly be used when your subject is much lighter or darker than the surrounding area. When used in apppriate circumstances it's a great feature. When used inappropriately, it can result in a dark surrounding area. The settings in auto were not using spot metering which is why they were different than the Av settings.
Mark
Nikon Z fc, Nikkor Z 16-50mm, Nikkor Z 40mm f/2, Nikkor Z 28mm f/2.8 (SE), Nikkor Z DX 18-140mm, Voigtlander 35mm f/1.2, Voigtlander 23mm f/1.2, DXO PhotoLab 5 Elite, DXO FilmPack 6 Elite, DXO ViewPoint 3
apersson850
Obviously it's a good thing
Gallery: 35 photos
Post edited over 6 years ago by apersson850.
Apr 19, 2017 03:26 |  #11
Listen to Mark. He has the correct explanation for you.
Just realize that the selection of AF points is a separate setting from light metering. The only time they interact is when using evaluative metering, as it gets information from the AF setting about what is most important in the picture.
More advanced models have more intricate relationships between AF and metering, but for a 7D, this is true.
Anders
mwsilver
Gallery: 54 photos
Joined Oct 2011
Post edited over 6 years ago by mwsilver. (5 edits in all)
Apr 19, 2017 09:29 |  #12
tmwhitm wrote in post #18331669 (external link)
Spot is not intended for general outdoor images. Is this a constant issue or only for a few selected shots? Did you review after taking the shots in spot? Did they look overly dark on the LCD? If so, when this occurs switch to evaluative or partial metering. Depending on the lighting and how extreme the difference between the subject and background is, using spot metering in order to get your subject exposed well could result in very dark backgrounds. It's a trade off. Thats why evaluative exists, to give you the best overall metering balance. If you could post a couple of examples for us, that would be useful.
Mark
Colin ­ Glover
Gallery: 17 photos
Joined Aug 2012
Apr 19, 2017 10:35 |  #13
Have you checked iso as well? Green box sets auto iso, so you need to set that the same. And then check metering pointer is as close to central as possible. Job's a good one!
Canon EOS 70D, Canon EOS 600D, EF-S 18-55 ii, EF 55-200 USM ii, EF-S 75-300 iii, Tamron 28-80, Sigma 70-210. Pentax 50mm, Pentax 135mm, EF-S 55-250, Raynox Macro adapter, Neewer filters (CPL, UV, FLD & ND4), Fuji HS20 EXR (30X zoom ) & cable release, Yongnuo 560 iii & Luxon 9800A manual flashguns for the Fuji, Hama Star 63 tripod, Hongdek RC-6 remote control, Velbon DF 40 www.point-n-shoot.co.uk website.
tmwhitm
Apr 20, 2017 18:57 |  #14
I did check the ISO but it was an after thought and I realized that the green box had set the ISO lower than what I had, 200 vs 100 so it wasn't completely apples to apples. I used the spot meter thinking, with a portrait and the focal point on the subject, the image would be exposed correctly. They did look dark in the LCD. I will test again but have to wait till the weekend.
Sgt.
Gallery: 56 photos
Apr 20, 2017 19:14 as a reply to  @ tmwhitm's post |  #15
Why dont you just shoot in manual?
Iain
7D MKII
Another minion in the Pondrader fan club
7,669 views & 4 likes for this thread, 9 members have posted to it and it is followed by 4 members.
EOS 7D Av Shooting
1458 guests, 128 members online
