Thread started 23 Apr 2017 (Sunday) 19:34
Flashpoint Evolv 200 curiosities...
dan.k78
Apr 23, 2017 19:34 |  #1
Has anyone else who has this strobe (with the R2 transmitter) experienced either of the two phenomena?
1.) If the Evolv is set on a particular mode (TTTl, Manual, Multi) that a speedlite mounted in the pass-thru shoe on top of the R2 will be forced into whatever mode the Evolv is in? This was annoying as I wanted the Evolv to be in manual mode and the shoe mounted flash to be in TTL to add a little fill.
2.) The pass-thru mounted speedlite will be randomly put into HSS or even Second Curtin mode?
I've read through the manual, but can't seem to find a reference to anything relating to the pass-thru shoe. Everything else about the strobe works perfectly, so I'm not sure if it is behaving like it is supposed to or if there is actually something amiss.
Thanks for any experiences anyone has had with this issue.
Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
mmmfotografie
hanging up-side-down in a cave
Joined Jul 2013
Apr 24, 2017 02:26 |  #2
Maybe you use the ongoing thread about this flash
https://photography-on-the.net …hp?t=1383549&go​to=newpost
dan.k78
Apr 24, 2017 06:29 |  #3
I had thought about that, but figured a separate thread would be more direct. I may pop my question into that thread as well.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Apr 24, 2017 06:35 |  #4
Sounds like more of a question with the Godox R2 system, than the AD200. I fail to see why the AD200 would control the other devices, when the R2 tx/rx are really in control of the lighting system attached to it.
dan.k78
Apr 24, 2017 06:43 |  #5
Agreed.
For whatever reason, the R2 isn't acting as a true "pass-thru", but rather syncing whatever the AD200 is set at with the attached speedlite .
agv8or
Gallery: 10 photos
Apr 24, 2017 15:37 |  #6
dan.k78 wrote in post #18336718 (external link)
Agreed.
The R2 (X1) is not a "pass thru" hot shoe. It treats TTL speedlites in the hot shoe as a Group A Slave. So if you have your Evolv set to Group A then this will be duplicated in the "on camera" Speedlite in the R2 hot shoe. Put your Evolv in a different Group or use a Manual only flash in the R2 hot shoe.
Rand
Gear
dan.k78
Apr 24, 2017 16:14 as a reply to  @ agv8or's post |  #7
I'll give it a try. Thanks for the advice :)
3,779 views & 2 likes for this thread, 4 members have posted to it.
1062 guests, 104 members online
