Thread started 25 Apr 2017 (Tuesday) 01:27
Any fix for the M5 shutter lag when external flash is mounted to it?
kaitanium
Apr 25, 2017 01:27 |  #1
Been searching around for a fix but im guessing there are none. When I shoot normally in low light situations that would require a flash, it shoots normal, fast (as fast as the shutter speed i set it to of course). Once I mount my 600ex on top of it, the screen would brighten up like crazy and pressing the shutter button down makes the camera hunt and focug for some 3-5 sec, then after it will take the pic! Ive never experience this slow in a camera. whats up?
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Apr 25, 2017 01:53 |  #2
must say I've not used an external flash on my M5 before - just tried a 580ex inside at night with only a 100w light in the room without any of the symptoms you've described.
Probably need more info - what mode are you using? what sort of ISO/speed/aperture?
TF posting: here :-)
kaitanium
Post edited over 6 years ago by kaitanium. (2 edits in all)
Apr 25, 2017 11:04 |  #3
Hmm weird. F2.8, Shutter 100, iso1600, manual, ef adapter to a 16-35ii
Must be some setting I have turned on or something. Flash on ettl. It was dark enough here to warrant that focus loght turning on on the camera
kaitanium
Apr 25, 2017 11:16 as a reply to  @ kaitanium's post |  #4
Something about low light that causes it to be super slow. I'm in a bright place now and it's fine.
GTogs
Joined Sep 2004
Apr 28, 2017 20:38 |  #5
Is it possible that the focus assist light is turned off?
Togs
kaitanium
May 01, 2017 14:28 as a reply to  @ GTogs's post |  #6
its on but that shouldnt matter as there is red beam assist coming from the flash? I dont know. This is a bit odd
Found a thread on dp on this: https://www.dpreview.c​om/forums/thread/41006​87 (external link)
eugenekamphoto
1 post
Joined Jan 2018
Jan 28, 2018 23:44 |  #7
I have the same problem. Im a pro photog and bought this camera for back up. Tried everything. Manual focus, turned off all view finder preview. Ive even had the camera replace. I love this cameras features and image quality but cant get the shutter to fire when flash attached. Hope there’s a fix.
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Jan 29, 2018 13:03 |  #8
eugenekamphoto wrote in post #18551453 (external link)
can you let us know what flash you've tried?
John ­ from ­ PA
Joined May 2003
Jan 29, 2018 18:37 |  #9
Long shot but do you have second-curtain sync enabled?
Wilt
Post edited over 5 years ago by Wilt.
Jan 29, 2018 18:45 |  #10
So, to stimulate a bit of thinking by the folks complaining about the M5...Is the problem specifically associated with
  1. low light only, or
  2. flash attached only, or
  3. low light + flash attached
John ­ from ­ PA
Joined May 2003
Post edited over 5 years ago by John from PA. (3 edits in all)
Jan 29, 2018 18:55 |  #11
kaitanium wrote in post #18343709 (external link)
I do note in that thread that Hebalers, down near the bottom, said "It happens at low light when you have a flash attached set to TTL." I believe most recent EOS cameras work best with E-TTL, not TTL. Of course that could be a typo.
Canon DSLR cameras only have E-TTL metering, the older film cameras have E-TTL and TTL to allow them to be used with both "new" and "old" flashes. Older Canon flashes from before the Speedlite EX series only provide TTL flash, not E-TTL.
I do note however, that you say you are using E-TTL. Might be worth verification that C.Fn 05 (on the Speedlight) is not set to 1.
Another thread at https://www.dpreview.c​om/forums/thread/41138​45 (external link) has quite a discussion. Go to page 5 and read the remarks about the Exposure Simulation setting. Some people found improvement with it Enabled.
And at https://www.dpreview.c​om/forums/thread/40962​18 (external link) somone quotes a Canon resource
"Thank you very much for your EOS M5 inquiry.
Regrettably, we must tell you that this camera model actually has a higher shutter lag in a dark environment when shooting with a flash, even in a completely manual mode when the shutter button is pressed down completely. This is constructive and can not be changed.
We apologize for any inconvenience, and we apologize for any inconvenience.
Best regards,
Anke Hunter
Canon Services & Support"
Wilt
Jan 29, 2018 19:17 |  #12
John from PA wrote in post #18552032 (external link)
Best regards,
Anke Hunter
Did Canon once again shoot themselves in the foot with something not done properly in connection with use of flash?!
:rolleyes:
musicmaster
Saw the Light
Jan 29, 2018 22:56 |  #13
Wilt wrote in post #18552048 (external link)
:rolleyes:
What was the prior?
Gripped 70D, Sigma F/2.8 OS, 70-200L F/2.8, 300L F/4 IS, EOS M5, 18-150, 22 2.0
Wilt
Post edited over 5 years ago by Wilt. (3 edits in all)
Jan 30, 2018 01:28 |  #14
musicmaster wrote in post #18552179 (external link)
What was the prior?
  1. Back in the days of the 20D and 30D, folks had to somewhat permanently crank in FEC = +1 in order to get eTTL to illuminate the scene to the same tonal values as would be achieved with ambient-only lighting. (Then suddenly, with the 40D, this corrective flash value ceased to be needed.)
  2. Although eTTL works properly with pointing the flash head upward to bounce illuminate exposure, eTTL flash automation does not seem to work properly when you put the flash into a softbox, for direct or indirect illumination.
  3. With the 580EXII, with the addition of the 'External' mode (flash photosensor Auto mode) would underexpose a scene by 1EV-2EV, compared to photosensor autoflash results with other brands of flash.
  4. Then with the 70D, there were complaints of bounce flash underexposure not experienced with other models of Canon dSLR, which went away in the 80D.
I (only somewhat tongue-in-cheek) have speculated that Canon puts brand-newly hired engineers just graduated from engineering school on the flash team, and then once they really know what they are doing, they are moved out from the flash department into lenses and bodies.
musicmaster
Saw the Light
Jan 30, 2018 10:48 |  #15
Wilt wrote in post #18552202 (external link)
Honestly, this sounds like a lot of issues that could be corrected via software/firmware updates. It's surprising they don't somehow address these issues.
7,713 views & 0 likes for this thread, 7 members have posted to it and it is followed by 2 members.
1507 guests, 135 members online
