I have a question. How is the ir red plastic cover held on to the flash unit? I have two of these and both of those covers are not tight, they have some movement if you touch them. Not a lot, but it doesn't seem to be glued on.
Apr 26, 2017 08:27 | #1 I have a question. How is the ir red plastic cover held on to the flash unit? I have two of these and both of those covers are not tight, they have some movement if you touch them. Not a lot, but it doesn't seem to be glued on. _______________
saea501 ... spilled over a little on the panties More info | Apr 26, 2017 15:55 | #2 Mine's pretty tight. I can feel a very tiny bit of movement if I press firmly and try to move it in multiple directions. I imagine it just snaps on using plastic tabs on the red thingy. If its not falling off....leave it. If it bugs you you can try to get a bit of super glue on the tip of a pin under the junction. Remember what the DorMouse said.....feed your head.
Apr 26, 2017 15:58 | #3 Its not a lot of movement in fact. Can feel ot sometimes when handling it. In fact the black plastic cover above it has slight movement too. _______________
DaviSto ... sorry. I got carried away! More info | Apr 26, 2017 16:26 | #4 No movement at all in my case ... even when I apply a bit of force. David.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 6 years ago by Wilt. | Apr 26, 2017 17:09 | #5 Unless you use IR commands for Master/Slave, to use the 430EX as an optical slave, it really does not matter. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Apr 27, 2017 08:26 | #6 Mine (2) don't move at all, with reasonable pressure and side force. Gerry
joeseph "smells like turd" More info Post edited over 6 years ago by joeseph. | Apr 27, 2017 14:45 | #7 they look to be held on by a clip at either end, see: http://i.ebayimg.com …/mVkAAOSwiCRUiNkA/$_1.JPG some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Apr 28, 2017 06:10 | #8 Thanks _______________
| Latest registered member is semonsters 1294 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
