Morning everybody
Just a quick question it seems like everybody at the camera club has their own ideal on which one to use for setting the white balance. So what are your thoughts on the subject.
May 05, 2017 02:17 | #1 Morning everybody Canon 7D Mark2 gripped,Canon 6D gripped, Canon 60d gripped,EF 70/200 F2.8 L IS 11 USM EF-100-400 F4-5.6L IS II EF 50 f1.8 ,EF 100 2.8 usm ,EFS18-135, EF 24-105 F4 L usm ,Tamron 70-300 SP 4_5.6 Sigma 150-500 , Manfrotto 190x prob with a Jobu jr.3 , Manfrotto 681b monopod. flickr
dpe Senior Member 283 posts Likes: 118 Joined Jan 2017 Location: Wareham More info | May 05, 2017 05:24 | #2 I was always told white for Canon and grey for Nikon, but have used both with Nikon UK based photographer specialising in equestrian but also doing things like Prom Photography
RicoTudor Senior Member 677 posts Likes: 386 Joined Jul 2014 Location: Chicago, IL More info | May 05, 2017 06:39 | #3 I use white because it's readily at hand and is most efficient with light. Gray works, too. Either way, be sure to avoid materials with a fluorescent treatment: such fabrics and paper will seem white, but actually emit excess blue in the presence of any UV (a component in sunlight and flash). I use untreated art paper from Blick. Canon, Nikon, Contax, Leica, Sony, Profoto.
PhotosGuy Cream of the Crop, R.I.P. More info Post edited over 6 years ago by PhotosGuy. | May 05, 2017 07:16 | #4 If you shoot on the meter, both should come up gray which is what you want. Actually, the tone shouldn't matter as long as the whites aren't blown & the blacks aren't crushed. FrankC - 20D, RAW, Manual everything...
ImageMaker... looks like I picked a bad week to give up halucinagens More info | May 05, 2017 08:21 | #5 I'm quite happy with the WhiBal card. Not quite white, not gray. Closer to white though. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
DaviSto ... sorry. I got carried away! More info Post edited over 6 years ago by DaviSto. | May 05, 2017 08:51 | #6 PhotosGuy wrote in post #18346869 If you shoot on the meter, both should come up gray which is what you want. Actually, the tone shouldn't matter as long as the whites aren't blown & the blacks aren't crushed. Gray Card…White Paper. What’s best? Ok I tried this method and it certainly works for exposure. Used plain white paper and +2 1/3 stops (7 clicks) and the histogram was bang up against the right margin with no clipping (5Div). David.
PhotosGuy Cream of the Crop, R.I.P. More info | May 05, 2017 09:17 | #7 DaviSto wrote in post #18346929 If you are using this for custom white balance. Is there also a way of getting the K value from the first white/grey shot or is this something that you adjust in PP, for example by using the eye-dropper in Lightroom? I've a feeling there's something I've missed. 1st, I don't use LR, so someone else will have to answer that. FrankC - 20D, RAW, Manual everything...
DaviSto ... sorry. I got carried away! More info | May 05, 2017 09:45 | #8 PhotosGuy wrote in post #18346950 1st, I don't use LR, so someone else will have to answer that. 2nd, I consider WB settings to be a guide for consistency while shooting RAW. Unless I'm shooting product, I will adjust WB during RAW processing to what I think works best for that shot, so I'll feel free to pick warmer/cooler as I go through the images. I might pick warmer AND cooler for 2 conversions of the same image & blend them together in PS. So for me, the "correct" WB isn't always the right" WB? Don't be afraid of fudging it a bit if you think the shot looks better. ![]() I'm experimenting with fully manual WB at the moment. I was surprised by how straightforward it seems. The results have been great (in WB terms, at least) and, as you point out, shooting RAW means I can always tweak in PP if necessary. I haven't found any need for this so far even for difficult lighting (e.g. strong sunlight through a canopy). I seem able to judge the K value (well, OK, guess it) about right. David.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | May 05, 2017 10:31 | #9 lonerider519 wrote in post #18346761 it seems like everybody at the camera club has their own ideal on which one to use for setting the white balance. So what are your thoughts on the subject. Simply keep in mind is that the concept of WB results in a 'neutral' value for R-G-B when the camera is recording a 'neutrally colored' surface...whenever you aim your camera at a black surface or a gray surface or a white surface (which fill the frame), the meter suggests an exposure which records that area as a 'midtone', resulting in R-G-B values close to 50-50-50 (on a scale of 100%). Cameras or software may reject setting WB when the eyedropper is too close to 100%, whereas when the values in the sample are 'more moderate' in value the eyedropper tool works fine. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
ImageMaker... looks like I picked a bad week to give up halucinagens More info | May 05, 2017 14:54 | #10 The goal of White Balance is to ensure proper accurate color. Not exposure. Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
RDKirk Adorama says I'm "packed." More info | May 05, 2017 15:18 | #11 If the RGB values are close to 255--which they are likely to be with a white sheet--then the value of any color above that will be incorrectly measured. If your exposure is already set to reproduce the sheet as white, then any predominant color is already above 255--the system can't identify that fact. TANSTAAFL--The Only Unbreakable Rule in Photography
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 6 years ago by Wilt. (2 edits in all) | May 05, 2017 15:36 | #12 RDKirk wrote in post #18347262 So you'd have to be careful to make sure the white sheet is underexposed to get an accurate balance. ^
---notice that NONE MATCHED for WB value and Tint setting! A cheap sheet of bond works, 'to get you close', but does NOT ensure color accuracy for color-critical reproduction. Kodak picture inkjet paper is very neutral. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
ImageMaker... looks like I picked a bad week to give up halucinagens More info | May 05, 2017 19:36 | #13 Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
May 06, 2017 01:44 | #14 Some great information on this topic. I have a white and grey card in my camera bag and i have even used the ice just before a hockey game as a custom white balance. Just wondering as when i get into lightroom or photoshop it seems easier to get the colors and skin tone closer when i do a custom white balance. I don't own a color checker but thinking one may be in my camera bag soon. Canon 7D Mark2 gripped,Canon 6D gripped, Canon 60d gripped,EF 70/200 F2.8 L IS 11 USM EF-100-400 F4-5.6L IS II EF 50 f1.8 ,EF 100 2.8 usm ,EFS18-135, EF 24-105 F4 L usm ,Tamron 70-300 SP 4_5.6 Sigma 150-500 , Manfrotto 190x prob with a Jobu jr.3 , Manfrotto 681b monopod. flickr
Pippan Cream of the Crop More info | A colorchecker's the best bit of kit I've bought. Take shot of it in the same light as your subject, then do a light source profile later when you're processing. Takes seconds. Perfect colour, then you can warm or cool to taste if you want but you start with it spot on. It's better than a grey (or white) card because light sources can vary a bit at different wavelengths, so just moving the scale up or down isn't quite the same. (Hoping that makes sense). Still waiting for the wisdom they promised would be worth getting old for.
| Latest registered member is semonsters 925 guests, 116 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
