Thread started 05 Jun 2017 (Monday) 05:17
Points to consider while getting a tripod or monopod?
rosh4u
Joined Jun 2017
Jun 05, 2017 05:17 |  #1
I never ever thought that i will require a tripod to shoot something but considering some past events its mandatory for me to get one. So what are the best points to check in first? Generally my Photography is based in candid landscape shots with 1/3 exposure.
Roshni Patel Co-founder of Auto Stamper (external link)
patrick ­ j
Gallery: 77 photos
Jun 05, 2017 09:08 |  #2
rosh4u wrote in post #18371297 (external link)
I think everyone will say to spend the money to get a good one the first time. Try to go cheap and you'll end up being dissatisfied and buying another tripod and spending more money in the long run. I think there are lots of good ones out there. As far as where the line is on the dollar amount for a good tripod, I'm thinking a little above $200, not including the head. If you are going to be lugging it any distance from a car, go with carbon fiber.
saea501
... spilled over a little on the panties
Gallery: 43 photos
Jun 05, 2017 09:44 |  #3
Are you doing long exposure stuff?
I don't use mine much but its nice to have when you do need something steady......better than a rock or a fence post.
I'm sure you're going to invariably get the recommendations to spend five or six hundred bucks on a Gitzo or Manfrotto. My friend has several Gitzos....I've used them, they work just fine. Are they better than my Slik? No. Both do the job they were designed to do. The difference is my ball head Slik was about $250.
Take all of the recommendations that you are about to get with a grain of salt. You don't have to spend big money to get a decent tripod.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
Luckless
Joined Mar 2012
Jun 05, 2017 10:23 |  #4
What exactly are you planning to DO with the tripod? How do you plan to use it, and under what kind of conditions, and with what kind of gear.
The tripod one takes backpacking through the mountains to hold up a point and shoot camera is probably not the same tripod you'll want for shooting an 8x10 rig in a studio.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jun 05, 2017 11:08 |  #5
Since most of your shooting is landscapes outside, you will have to carry it more than just out of the trunk of your car.
I have light ones & heavy ones, but the one that I've taken all over the US is the Tiltall. I bought it in 1965 & it's never given up. I do suggest that you get a quick release for the camera.
http://tiltallsupport.​blogspot.com/p/tiltall​-support.html (external link)
http://tiltalltripod.c​om/Aboutus.html (external link)
You can get a used Tiltall Tripod (external link) for about $75US.
flyfisher
Post edited over 6 years ago by flyfisher.
Jun 05, 2017 16:08 as a reply to  @ PhotosGuy's post |  #6
There are many variables to consider you say you want it for landscapes witch would make me think carbon fiber for it's lighter weight.
You don't say what size and weight of the equipment that you plan to use it with as you do not want to have you that is not sturdy enough for your equipment as it could tip over very easily.
How much you spend is a personal decision but look for one with slightly higher capacity than you think you need you won't regret this in the long run.
Steve
Talley
Talley Whacker
Gallery: 46 photos
Joined Dec 2011
Jun 17, 2017 14:50 |  #7
Remember carbon fiber is yes about saving weight but it's also about vibration dampening which carbon fiber does much better over the aluminum.
The points to consider is get the largest one you can feasibly carry period. If you think it's strong enough then get stronger. Take the rated capacity by the specs and divide by 4 and thats the actual max you should load if your taking shots that are in the 15s+ range. Remember what might seem stable in your house may not be in the field where you have wind.
I use to have a middle range one but it wasn't really good a vanguard alta plus 253 carbon fiber. It was rated for 13lbs. I now have two sirui's a small one and their largest. These are leaps and bounds better than the vanguards.
A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
My Gear Archive
eddieb1
Joined Apr 2013
Jun 17, 2017 15:32 |  #8
saea501 wrote in post #18371416 (external link)
Perfect response. You'll always find people who are ready to spend your money. Go out to your local camera store, take your camera and lens with you. Try various tripods, set your spending limit, and select one that meets your needs. Don't be swayed by anyone who says you need to spend big bucks for quality. You don't.
3,239 views & 1 like for this thread, 8 members have posted to it and it is followed by 5 members.
1522 guests, 132 members online
