Ok, I am a newbie when it comes to lighting and my post will likely show that very much...
I am in Manual Mode - 1/250 at 8.0 at 400 ISO
When I use my YN in Manual mode with power at 1/2 - the image is on the cool side
When I use my Canon in Manual mode with power at 1/2 - the image is on the warmer side (while warm, it is much better than the YN).
I have adjusted the power on the flash units as I realize they are different sized, but I didn't expect such a drastic different.
I clearly must be doing some thing wrong.
What is happening here?
What am I doing wrong?
NOTE: I am hoping to be able to dial in the YN to look like the Canon was used.
I am using the same batteries.
The YN is a couple years old, but rarely used. Purchased new.
The Canon is brand new.
Cooler image is with YN/Warmer image is with Canon. Both SOOC
EXIF from image using YN Flash
File Name IMG_6063.CR2
File Size 22.2MB
Camera Model Canon EOS 70D
Firmware Firmware Version 1.1.1
Shooting Date/Time 6/16/2017 5:12:39 PM
Owner's Name
Shooting Mode Manual Exposure
Tv(Shutter Speed) 1/250
Av(Aperture Value) 8.0
Metering Mode Evaluative Metering
ISO Speed 400
Auto ISO Speed OFF
Lens EF-S18-135mm f/3.5-5.6 IS STM
Focal Length 35.0mm
Image Size 5472x3648
Crop/aspect ratio 3:2
Image Quality RAW
Flash Off
FE lock OFF
White Balance Mode Auto
AF Mode One-Shot AF
AF area select mode Manual selection
AF Microadjustment 4
Picture Style Neutral
Sharpness 0
Contrast 0
Saturation 0
Color tone 0
Color Space sRGB
Long exposure noise reduction Auto
High ISO speed noise reduction Standard
Highlight tone priority Disable
Auto Lighting Optimizer Disable
Peripheral illumination correction Enable
Chromatic aberration correction Enable
Dust Delete Data No
Drive Mode Single shooting
Live View Shooting OFF
Camera Body No. 072024002683
Comment
EXIF from image using Canon Flash
File Name IMG_6061.CR2
File Size 21.9MB
Shooting Date/Time 6/16/2017 5:10:11 PM
Owner's Name
ISO Speed 400
Auto ISO Speed OFF
Focal Length 35.0mm
Image Quality RAW
Flash On
Flash Type External Flash : Manual Flash
Flash Exposure Compensation 0
Shutter curtain sync First-curtain synchronization
FE lock OFF
AF Mode One-Shot AF
Sharpness 0
Contrast 0
Saturation 0
Color tone 0
Color Space sRGB
Dust Delete Data No
Comment
