Thread started 19 Jun 2017 (Monday) 14:41
Precision Color ink refillers - Post your experiences and advice please
Nathan
Can you repeat the question, please?
Gallery: 18 photos
Post edited over 6 years ago by Nathan. (2 edits in all)
Jun 19, 2017 14:41 |  #1
I'm looking into the precision color ink refills as a more cost effective (and for me space saving) option. I've gotten by upgrading printers buying whatever is on Craigslist for the cost of set of branded ink refills and more recently jumped on that free paper deal. Now I have too many unused printers in the basement that I need to get rid of and several boxes of paper.
I'm on the Precision Color website and I'll probably just get the 32 oz kit with a full set of cartridges... what do you think?
Advice? What should I know?
For example, what does "purge" mean? I don't understand the process and reasons for it below.
05Xrunner wrote in post #18224623 (external link)
Dont replace 1 cart at a time if your refilling. everytime you replace a cart the printer will purge all 8 carts. So then you are wasting alot of ink then you will be on a cycle of replacing one cart every week cause of it and purging all 8 each time. Then once the pads in the printer are 100 saturated they cannot take anymore from purges or cleaning the printer is basically dead. I have 2 sets so when 1 ink cart is low and about to run out i swap all 8 out. so its only 1 purge cycle and then refill all the ones i pulled ready to go in the next time 1 goes low. so you are doing ALOT less ink purges and saving alot of ink
Taking photos with a fancy camera does not make me a photographer.
www.nathantpham.com (external link) | Boston POTN Flickr (external link) |
5D3 x2 | 16-35L II | 50L | 85L II | 100L | 135L | 580 EX II x2
hidroela
Gallery: 40 photos
Joined Jul 2014
Jun 19, 2017 14:51 |  #2
Nathan wrote in post #18382090 (external link)
first thing I did when I bought my Canon printer was to get the 32 oz, I refused to pay that much for there's (canon). all that been say, i am happy with the results. take note I am not an expert in photo printer.
Pérez
GEAR
agedbriar
Post edited over 6 years ago by agedbriar.
Jun 19, 2017 15:55 |  #3
Refillers gather here:
https://www.printerkno​wledge.com/ (external link)
Purging, in that context, means priming the cartridges (with some ink wasting).
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jun 20, 2017 03:47 |  #4
You have one cartridge that is empty, one that is an eighth full, one a qtr full, and five half full.
When you replace the one empty cartridge the system has to flush out the residue from the old cart so that you only have the new ink (to avoid any colour differences in the two causing problems). However they don't just flush the one ink they flush all 8 (which uses up ink meaning you will have to replace them sooner).
Two weeks later the second cartridge (that was an eighth full) runs out, so you replace that and the whole system gets purged again wasting more ink. Then three weeks later again and again. Each time you replace one cart all eight get purged.
The solution is to not just replace the one empty cart but also all the partially empty carts at the same time. That way the system will do a purge of all 8 as usual but now all the carts are full, so in two weeks you won't have to replace another cart (with another purge) and then do the same again in three weeks (with another purge).
Dan Marchant
Nathan
Gallery: 18 photos
Jun 20, 2017 15:14 as a reply to  @ Dan Marchant's post |  #5
Oh, okay. So, something like this. Nothing's ever really 100% full due to the purge.
Ink Levels
Full 3.99 LGY C PC BK
3.00 LGY GY C M PC BK
Half 2.00 LGY GY C M PC BK
1.00 LGY GY PM C M PC BK
Empty 0.00 LGY GY PM C M PC Y BK
Yellow is zero, so it needs to be replaced. Once you do, a "purge" occurs to get rid of residue (on the head?). Let's say the purge is .01 of an ink level. It brings down all other cartridges to by .01? Yellow, however, is actually 3.99 at that point?
Ink Levels
Full
3.98 LGY C PC Y BK
2.99 LGY GY C M PC Y BK
Half 1.99 LGY GY C M PC Y BK
0.99 LGY GY PM C M PC Y BK
So with the example above, when one cartridge needs replacing, you actually pull out all 8 and replace with the fresh set. Then you refill the old set and put aside. Wouldn't this create a potential for color difference problems between new and old ink in all the cartridges that are refilled back to full?
agedbriar
Jun 20, 2017 15:55 |  #6
Nathan wrote in post #18382900 (external link)
Yes, that's general practice among refillers and I've never heard of problems fom topping up partly used cartridges with fresh ink .
The reason for adopting that practice isn't only wasted ink cost (not that high with refill ink) but also to keep the waste ink absorbing pads from filling up too soon, consequently requiring an expensive service repair that can exceed a new printer's price.
But do visit the site I linked to above. There are things to watch out with refilling, like absolutely avoiding refilling the more recent original Canon yellow dye cartridges due to the gelling phenomenon.
This is just a sample thread on that issue:
https://www.printerkno​wledge.com …ellow-gelling-issue.9593/ (external link)
Nathan
Gallery: 18 photos
Jun 20, 2017 21:34 as a reply to  @ agedbriar's post |  #7
Thanks, I read about that and Precision Color basically reminds you over and over again on their site as you're checking out. But I will look at the rest.
Nathan
Gallery: 18 photos
Jul 02, 2017 21:34 |  #8
So I'm about to order some Precision Ink. I have two sets of old OEM cartridges that I haven't thrown out. Should I flush these and re-use or should I purchase the refurbs from Precision Color?
Nathan
Gallery: 18 photos
Jul 30, 2017 20:34 |  #9
I got my ink, but I'm a bit unclear about what to do with my existing cartridges.
Can I just reset and refill my 1/2 full OEM cartridges with Precision color ink? Would there be a problem with the Precision Color and OEM ink mixing? I know I should replace the entire yellow cartridge.
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Jul 30, 2017 20:56 |  #10
I may be wrong but I don't think mixing is a good idea. The PC inks will have their own color profiles as well so I don't think the chemical formulation is the same.
If you want to go down the Inkjet rabbit hole then subscribe to this guys YouTube channel...
https://www.youtube.co​m …/UCz9YXaSulpM90​vC24lmAeZA (external link)
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
Nathan
Gallery: 18 photos
Jul 30, 2017 22:58 as a reply to  @ FarmerTed1971's post |  #11
Already watched a couple of his videos. Informative, but the guy talks a lot. I was looking for a quick answer. I have an event coming up where I'm printing on the spot. Just wanted to know what's the best way to go about it. I think I'm going to run through the OEM until one of them runs out. Then, I'll pop in the Precision Color inks I bought. If I run out again during the event, I'll just squeeze more into the Precision Colors. Figure out what to do with the OEM later... flush, etc. Would be nice just to be able to mix the inks, though (except for yellow. I know not to do that).
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Aug 01, 2017 00:07 |  #12
Nathan wrote in post #18415011 (external link)
You need to replace all the OEM inks with the new ones and then you will most likely need to create a new profile for the new printer/ink/paper combination because the OEM ink profile you are using now won't be valid any more.
Mixing them would almost certainly be a bad idea. No way of knowing if the inks would actually mix properly or what the Frankinkstein Monster creation would look like.
Dan Marchant
lacogada
Joined May 2015
Post edited over 6 years ago by lacogada.
Aug 01, 2017 03:48 |  #13
Here is an email I sent to PC and their reply
Can your ink be mixed with Canon OEM ink ?
Does your CLI 42 chip re-setter work on the Canon OEM carts ?
Yes, it can be mixed with OEM ink. (not yellow)
The re-setter is guaranteed to work with OEM carts and chips. Over 10,000 in the field.
Mike
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Aug 01, 2017 08:28 |  #14
Interesting. CAN be mixed... but does it yield correct colors?
Nathan
Gallery: 18 photos
Aug 01, 2017 10:33 |  #15
I found another board that discussed it and it seems to be what people do. They top off their OEM and little to no issues.
10,485 views & 10 likes for this thread, 11 members have posted to it and it is followed by 8 members.
1458 guests, 127 members online
