Baseball on a sunny day
Jun 24, 2017 12:38 | #1 Baseball on a sunny day Image hosted by forum (861814) © ScooterShooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (861815) © ScooterShooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Jun 24, 2017 12:46 | #2 Nice action capture in #1, but I think it could use a little sharpening. In #2 I'd crop tighter to eliminate the sign on the right and I'd put some more light on their faces in post processing. -- Image Editing OK --
You don't need to get into too much detail, but how do I increase the light on faces without washing out other areas? (I am using Lightroom.)
Qbx Goldmember More info Post edited over 6 years ago by Qbx. | Select your photo from your LR library, then in the upper right you'll see: Library Develop Map Book Slideshow Print Web. -- Image Editing OK --
Jun 24, 2017 20:26 | #5 Qbx wrote in post #18385940 In #2 I'd crop tighter to eliminate the sign on the right and I'd put some more light on their faces in post processing. Is this what you had in mind? Image hosted by forum (861878) © ScooterShooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
rrblint Listen! .... do you smell something? More info | I think that you overdid it a bit, it looks unnatural. Either lower the exposure some or try again with lowered opacity on the brush. Mark
Yes. That crop looks better, but you ended up with them in dead center of the frame. You could open up the space to the left, which is the direction they are looking and it would be more pleasing. You might also try to sharpen the guy's face on the left a bit. He seems to be slightly OOF, so it may not help. Although rrblint has a point, I doubt that the players would notice. -- Image Editing OK --
How about this? Image hosted by forum (862158) © ScooterShooter [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Jun 26, 2017 19:40 | #9 Baseball is fun! Think about getting more of your subject(s) in focus by extending your depth of field. The firsr one looks out of focus, or maybe it's heat/haze causing me to think so. Also, if you can, move around to get a more pleasing or appropriate background. That could be difficult though. _______________
DanMarchant Do people actually believe in the Title Fairy? 5,634 posts Gallery: 19 photos Likes: 2056 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Jun 26, 2017 21:02 | #10 Qbx wrote in post #18385991 ....Move your cursor into your image area to the left. You should see a circular shape. This is the brush. Make it smaller or larger with [or] keys (left or right bracket keys). Make it sized to fit the area (the face in this case) you want to adjust, then click over the area. You can move it around and paint different areas. Then use the Exposure slider to brighten or darken the area that you painted. Other sliders will also modify the painted area accordingly. That's the basics. What Qbx said, but I would use the shadows slider not the exposure slider. Lifting the shadows will even out the face, whereas Exposure will brighten both the shadow area and the bright area (which is already bright). Dan Marchant
Now the composition looks right to me. -- Image Editing OK --
| Latest registered member is Monkeytoes 1364 guests, 179 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
