Thread started 26 Jun 2017 (Monday) 20:36
Monitor Suggestions/Advice wanted
ukfalc
Joined Apr 2012
Jun 26, 2017 20:36 |  #1
I am looking to replace my monitor and am looking for a 24 inch IPS screen with 16:10 aspect ratio, (1920 x 1200). It will be used mostly for photo editing (Lightroom and Photoshop), but also used for watching videos, using MS Office and browsing the web.
I am being drawn towards 3 possibilities. The first is the Asus PA248Q, which is marketed on the basis of its "professional grade colour fidelity" and being pre-calibrated. The second is a Dell U2412, which seems to be the best of the cheaper alternatives. The third is the Eizo CS2420, which appears to be a very serious step up in terms of quality and comes with a 5 year warranty - but costs £200 more than the Asus and is more than double the price of the Dell.
I am someone who is generally prepared to pay more for better quality (within reason) am therefore drawn towards the Eizo brand. However, I don't need its wider colourspace and wouldn't benefit from it as I am only an enthusiast who posts my pictures online and prints few photos. I have no experience using wide gamut monitors and have read about the oversaturation issues when using them for web browsing and watching videos etc. I am also seriously concerned that I could get in to a knot setting up the monitor for SRGB only and/or switching between the different the Adobe and SRGB colour spaces when processing photos and doing different tasks etc.
If I was to buy the Eizo, presumably I could avoid the oversaturation problems and keep things easy for myself by running it in SRGB mode all of the time? How easy would this be to set up? I appreciate that this would obviously forego the benefits (if any) of having a wide gamut monitor and makes me wonder what I would gain by spending more for the Eizo. Is there any difference in performance, quality or colour accuracy between an SRGB monitor, and a wider gamut monitor being run in its SRGB emulation/mode? Would a SRGB monitor like the Asus/Dell display photos better (and more accurately) than the Eizo being run in SRGB emulation/mode, would there be no difference, or would the Eizo's 10 bit technology (and presumably superior panel and build quality?) enable it to "do SRGB" better?
Sorry if these are stupid questions, but any thoughts/recommendatio​ns would be welcome.
Canon 5D Mk IV; Canon 7D Mk II.
EF 16-35mm F2.8 L II USM; EF 24-70mm F2.8 L II USM; EF 70-300mm F4-5.6 L IS USM; EF 100-400mm F4.5-5.6 IS L II USM.
http://www.alan-evans-photography.com (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 26, 2017 21:07 |  #2
I honestly don't know the answer to your last question, but if it were me, and I was going to run in SRGB all the time, I'd save a lot and get the DELL.
The Eizo's are best and geared to people that are seriously into wide gamut high bit depth etc. It sound a lot like buying the Ferrari to run on a 55MPH limited course to me.
CDS' HOT LINKS
davesrose
Title Fairy still hasn't visited me!
Jun 26, 2017 21:07 |  #3
RE: over-saturation issue with higher gamut monitors: that's becoming less of an issue with more standards that support ICC profiles. I also wouldn't trust "pre-calibrated". I say along with getting a monitor, also invest in a calibration system. I've got a X-rite ColorMonki (retails for $160 in the States). It's good because it will check what colors your monitor is able to produce, as well as figure a good contrast ratio for the specific ambient light environment you're in (so you can leave it plugged in and it will continue to check ambient light levels). It then creates an ICC profile that the OS will default to. Windows image viewer didn't use to support ICC, but Windows 10 does. You can also set the calibrated ICC to your working space in Photoshop. Many web browsers support ICC profiles, but if you want to be extra safe and export to sRGB, you can preview the difference under view/proof setup (then enable proof colors). I'd say get the monitor you can afford to get along with a calibrator.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
itsallart
Gallery: 1095 photos
Joined Jan 2015
Jun 26, 2017 21:18 |  #4
I just upgraded to ViewSonic VP2770 and couldn't be happier with it. But I don't know enough about monitors; my son who is an IT guy selected it for me based on my needs, mainly photography running PS etc.
Renata
Seeing lights and shadows is an art :)
My Vinyl Source (external link)Tanami Muse (external link)
500px (external link)
Face Masks on Etsy (external link)
Hen3Ry
Post edited over 6 years ago by Hen3Ry. (2 edits in all)
Jun 30, 2017 10:52 |  #5
I think if you buy the Eizo, you'll be spending a lot of money you don't need to spend to accomplish the goals you listed.
On the other hand, it will provide superior working images in post processing, if you should later want to render those images on paper.
Note that the first two monitors don't provide any specs regarding color rendition, while the Eizo provides a percentage of rendition capabilities. As does this monitor (external link), which is midway between the the first two and the Eizo in price. I've been using Dell Ultrasharps for years, and have never had an issue.
If I were you, I'd keep a close watch on Craigslist and eBay. There are a lot of monitors out there that were bought by people who thought they wanted to do post processing, but just never got around to doing it. E.g., I just bought an NEC Multisync 30 inch LCD3090WQXI with built in XRite calibration. It sells for about 1100 bucks, but I got it new in an open box for $150. It was a five hour round trip by car, but worth it.
Je n'avais pas besoin de cette hypothèse-là.
DCBB ­ Photography
Gallery: 478 photos
Jun 30, 2017 11:00 |  #6
You might want to take a look at this one as well, you get a lot of the Eizo peformance for significantly less
NEC MultiSync PA272W
John
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Jun 30, 2017 11:36 |  #7
I just had to buy a new monitor and opted for an LG 34" ultra wide IPS monitor. Covers all I need it to do, gaming/photography/vid​eo.
Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
Peano
Jun 30, 2017 12:22 |  #8
I have a Dell U2415, which is very similar to the U2412 but costs a few dollars more. I use it for commercial retouching and have been completely satisfied with it. I don't think you would go wrong with the 2412. Here's a comparison review:
http://www.techwarn.co​m/u2412m-vs-dell-u2415/ (external link)
Peano
RadiantPics.com (external link)
kv968
Joined Jul 2014
Jul 01, 2017 04:36 |  #9
When I was looking for a monitor about 2 or 3 years ago I was deciding between the same two monitors, the Dell and the Asus, and I went with the Dell and love it. Looks great and haven't had any problems whatsoever with it. I calibrate it with a Spider Pro 4 and go from there. I do notice though sometimes I can see the calibration "kick in" after turning the computer and monitor on and it seems to give the monitor a little yellow cast (at least to my eyes). However I wouldn't put that on the monitor nor the calibration but more on my eyes. That's probably how it's supposed to look and I get used to it quickly and stuff never comes out with a yellowish cast or anything when I view them on multiple devices. Except for my Zenfolio site which seems to saturate the reds a bit much sometimes but again that's probably the site itself and not the monitor.
I didn't do any research into the Eizo model but if you're decision is down to being between the Asus and the Dell I wouldn't hesitate going with the Dell. One thing you may want to keep in mind however is that the Dell doesn't have an HDMI port whereas the Asus does but even if you want to go that route you could always buy a converter.
Kevin
instagram.com/shooting​anything (external link)
Smitty2k1
Gallery: 22 photos
Joined Mar 2012
Jul 01, 2017 07:35 |  #10
I recently gave my U2412M to a friend and bought a 34" LG Ultrawide (34UM88). Very happy with this monitor for general productivity, gaming, and especially photo editing. I do a lot of landscapes so the extra width is very nice.
Gungnir
Gallery: 37 photos
Jul 05, 2017 15:51 |  #11
I too have just gone large (BenQ BL3201PT) after using the Dell 2412 for a few years. Great monitor but with camera resolutions rising 1920x1080 just wasn't working for me anymore. Colours were spot on and never shifted after calibration. The wide gamut made jpgs look wrong in windows photo viewer but irfanview etc display them properly.
Steve
'Be the person your dog thinks you are'
#freetommy
3,768 views & 10 likes for this thread, 11 members have posted to it and it is followed by 5 members.
1310 guests, 173 members online
