kjonnnn wrote in post #18398613
Just get Micosoft ICE. You'll be happy.
Since I already have LR/ACR and this is a feature, I thought I would run a comparative test between LR/ACR and ICE in doing a merge on a three image off the cuff hand held series of shots. In each case the three CR2 files were merged and processed only in the respective programs. In the case of ICE I saved the image to a PSD file and opened in PS. For the DNG version it was processed in LR/ACR and opened to PS. I then ran identical export processes on both images. I did it that way so that the JPEG conversion would be identical in both cases.
The LR/ACR image
Image hosted by forum (
864633)
© BigAl007 [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Compared to the ICE image
864634)
© BigAl007 [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. I would say that if you want to start from a RAW file, and maintain that level of quality/processability then the Adobe RAW photomerge option has a lot going for it. If you are already using LR/ACR as your RAW editor you can create the merged image while retaining all of the original camera data for your normal RAW workflow. It looks to me as if ICE simply pulls the JPEG preview out of the file and uses that. Not a great option if you use the Canon Faithful picture style, with contrast and sharpness turned right down, to get an in camera histogram close to the RAW data, as I do.
ICE is fine when working with RGB files, but as someone who uses LR and has a workflow where 98%+ of images remain only as RAW files on my local computer, the merge to DNG option is a much better one, since for a start I don't need to set an image bit depth, or colour space until I export the finished image. The option to build a static panorama from a video clip seems like an interesting option, especially if it will do it from 4K video. This is why I keep ICE on my machine, even if I don't use it very often.
One thing I noted when saving to PSD from ICE, if you include all of the layers, it places the final composite layer at the bottom of the layer stack, so you only see the stack of original image layers, without the application of the blending. I initially thought there was something wrong with the image file in PS compared to that seen in the ICE window.
Alan
