Thread started 28 Jul 2017 (Friday) 18:26
How to get a "cone of light" on seamless background?
moodlover
Joined May 2014
Post edited over 6 years ago by T.D. with reason 'Image not belonging to OP may be linked but not embedded.'.
Jul 28, 2017 18:26 |  #1
Hi all, found this lovely still life by photographer J. Tasker:
http://i.imgur.com/IFp​HCp3.png (external link)
I have a small Yongnuo 560-IV speedlite with 9" soft box I would like to dedicate to this task but can't figure out how to make the triangle/cone shape of light that starts small at the top and expands as it comes down. I love how it lands behind the flower pot and is the brightest point of that light. I will be doing this for portraits, not still life.
Also, I have a roll of cinefoil available (but not really sure how to use it) if that will help cut light from the sides like the reference. Is the background light a hard light? Soft light? I really don't know and would appreciate help, thanks!!!
OceanRipple*
Joined Dec 2014
Post edited over 6 years ago by T.D. with reason 'Uploaded image not belong to OP removed'. (2 edits in all)
Jul 29, 2017 03:49 |  #2
Hi, For a narrow cone, medium hard light but smooth transitions, one approach is a Fresnel (this one by 'Aputure'), fully focused/extended and 10 degree grid. I needed cinefoil to cut out stray light from the ventilation holes:
.. just a test ..
mmmfotografie
hanging up-side-down in a cave
Joined Jul 2013
Jul 29, 2017 04:57 |  #3
Just put the head of the speedlite close or against the background. You can incoming spliligth with the cine foil. That's is all and you can control the width of the cone at the top with the distance to the background and the bottom with the zoom of the speed lite.
Lotto
Jul 29, 2017 05:03 |  #4
I'll give it a shot, with grid and barn door. And with the proper backdrop, I think I could make the bottom part brighter.
Cinefoil can do the same, just lots of trial and error without the modeling lamp.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/07/5/LQ_867803.jpg
Image hosted by forum (867803) © Lotto [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/07/5/LQ_867804.jpg
Image hosted by forum (867804) © Lotto [SHARE LINK]
5D, 24-105L, 70-200L IS, 85mm Art, Godox
Lotto
Post edited over 6 years ago by Lotto.
Jul 29, 2017 05:09 |  #5
A fog machine or lots of flying dust would work too :)
williaty
Joined Feb 2017
Jul 30, 2017 00:44 |  #6
The light leaves your light as a cone. When you "slice" the cone shape beam with the wall, you get a conic section projected onto the wall. The conic section you're most likely to see is a parabola. Sorry for dragging you back to middle school geometry class! The parabola will be more clearly formed if 1) The light all originates from a single point (so no softboxes, umbrellas with diffusion, etc) and 2) there's something limiting the angle of the cone (so no bare bulb). In other words, good, sharp parabolas of light on the wall be created things like fresnel lenses, reflectors with grids, TRUE parabolic modifiers like the Elinchrom Fireball, PCB 11" Long Throw or Retro Laser Reflector, or projection heads like the Profoto Spot Small.
sincity
Joined Nov 2014
Jul 30, 2017 07:04 as a reply to  @ williaty's post |  #7
Could the OP also use those projector-type modifiers?? I modified a F-16 Turbo Spot from a Photogenic mount to Elinchrom just by changing out the seven-inch reflector. Amazon has them as discontinued, but I do see the Turbo spot on eBay as well as garage sales. So it might be worth a look
Link to Amazon~~
https://www.amazon.com …arp_d_product_t​op?ie=UTF8 (external link)
williaty
Joined Feb 2017
Jul 30, 2017 10:51 |  #8
sincity wrote in post #18414526 (external link)
Link to Amazon~~
Yeah, same thing. The affordable ones tend to be fresnel attachments, the more expensive ones are usually condensor arrangements made of plano-convex lenses.
abbadon31
Gallery: 264 photos
Best ofs: 10
Jul 30, 2017 13:17 |  #9
7" reflector
I AM SHOM
tdlavigne
Joined Mar 2015
Jul 30, 2017 15:25 |  #10
Off the top of my head:
Fresnel with barndoors
Zoomspot or any generic ellipsoidal spot
Flags and reflector
Photoshop
I'm fortunate enough to have Leko spot converted to my lights, but if I didn't I'd opt for a combination of #3 and 4
F2Bthere
Joined Oct 2015
Aug 03, 2017 10:20 |  #11
I think you just use your speedlight, set it fairly close to the wall (background), start with it zoomed to the longest setting and play with the angle to the wall (background) to get the affect you want.
You shouldn't need a fresnel, since that is, essentially, what you already have with your speedlight.
You can make it more complicated if you want... ;)
C&C always welcomed...
On my images, of course, and on my words as well--as long as it's constructive :).
https://www.instagram.​com/storyinpictures_co​m/ (external link)
3,843 views & 0 likes for this thread, 9 members have posted to it and it is followed by 3 members.
Latest registered member is RawBytes
1572 guests, 156 members online
