Thread started 15 Aug 2017 (Tuesday) 11:52
Aurora 2018 coming in September
MCAsan
Joined Jun 2010
Aug 15, 2017 11:52 |  #1
Availability: Aurora HDR 2018 will be availabe for pre-order on September 12, and released on September 28.
Pricing: Mixed-computer households can share the same product key for Mac and PC that can be activated on 5 devices.
Pre-order: Current users of Aurora HDR may upgrade at a special pre-order price of $49. New users can purchase Aurora HDR 2018 at a special pre-order price of $89. A collection of bonuses will also be included with every purchase.
Retail price: $59 for current Aurora HDR users, $99 for new users
http://www.43rumors.co​m …windows-mac-september-12/ (external link)
Stiga
Gallery: 908 photos
Joined Dec 2015
Aug 15, 2017 13:30 |  #2
Thanks for the heads up :-)
Martin
I'm not a gear guy but I have a tons of software :-)
kirkt
Aug 15, 2017 15:21 |  #3
Have you watched the announcement video?
https://aurorahdr.com/​2018 (external link)
click on the "watch video" link.
Trey Ratcliff ... seriously, dude. It embarrassing.
kirk
Kirk
MCAsan
Joined Jun 2010
Aug 15, 2017 15:36 as a reply to  @ kirkt's post |  #4
Agreed Trey way out in left field. His presets have 60s acid trip names and most are way over the top. Thank goodness you can use them if you back off the opacity.
kirkt
Aug 15, 2017 16:01 |  #5
MCAsan wrote in post #18428572 (external link)
The software still cannot merge 3 shots of a tree against gradient blue sky without creating horrible color artifacts in the sky. If you want to make Trey-style images though, the software is tops.
kirk
Kirk
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Post edited over 6 years ago by Picture North Carolina.
Aug 16, 2017 08:22 |  #6
kirkt wrote in post #18428596 (external link)
kirk
Re: "software still..."
Are you a beta tester? Are you speaking of the new 2018 not yet released?
Website (external link) |
kirkt
Post edited over 6 years ago by kirkt. (4 edits in all)
Aug 16, 2017 08:42 |  #7
Picture North Carolina wrote in post #18429082 (external link)
I am not a beta tester. I am referring to the current version. When the application was first released, I tested it and found that it could not do this simple task. I even emailed the devs and provided them with the test files. They responded and thanked me and that was that. Apparently they have not addressed whatever the issue is in their algorithm.
Each time I get an email with a announcement that they have come out with an update, I download the trial again and run the same files through the new version. So far, there is no improvement.
Here are the three raw source files I use, if you want to try them yourself:
-2 EV: https://www.dropbox.co​m/s/kfc9splq7mm3yjj/3.​CR2?dl=0 (external link)
0 EV: https://www.dropbox.co​m/s/a4c1kx35szqv5nk/5.​CR2?dl=0 (external link)
+2 EV: https://www.dropbox.co​m/s/gfyn4zwkoueh5wb/7.​CR2?dl=0 (external link)
This is a simple scene, one that I would think is typical of a landscape with what I would call medium dynamic range - if you try hard enough, you can squeeze an acceptable image out of this -2 EV Canon 5DII image file. The scene has tree branches that were moving in the wind, so it is also a good data set to test ghosting removal.
Have fun! If you manage to get them to produce non-artifacted output, please post the result here and explain how you did it. The major issue is in the sky - there are colored bright blue haloes around the tree branches and the lower part of the sky loses color and becomes a sickly gray.
The application is supposed to be easy to use, but I cannot undo the effect, even with all of the controls turned off. I must be incapable.
kirk
Kirk
Stiga
Gallery: 908 photos
Joined Dec 2015
Aug 16, 2017 09:01 |  #8
Kirk, that's interesting, especially as I have not seen it mentioned in any reviews. All "professional" reviews online have to be treated with a pinch of salt as the bracketed sets they use are not difficult enough.
Martin
kirkt
Aug 16, 2017 11:39 |  #9
Stiga wrote in post #18429113 (external link)
Martin I agree, that's why I test everything myself. I have not watched the Aurora videos on the MacPhun site in a while, but I seem to recall that Trey Ratcliff's demo videos all involved using a bracket of three JPEGs to make the composite images as he talked about the software. I get it, it makes the software look fast and all that. However, I think the test image sets also hide the problem I see recurring over and over in the tree-sky scene. The demo images are typically busy scenes with lots of detail and not a lot of open, smooth areas of tone.
Again, I am probably wrong or over generalizing regarding the videos, but my own testing indicates there is a problem. I hope they solve it!
kirk
Attached is a screenshot of the artifact to which I am referring. I employed deghosting on the image because of the tree branches moving between shots, and used the underexposed shot as the reference.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/08/3/LQ_871061.jpg
Image hosted by forum (871061) © kirkt [SHARE LINK]
Kirk
kirkt
Aug 16, 2017 11:45 |  #10
And here is the underexposed single raw image, converted in RPP with some local contrast added. If you load the single underexposed raw into Aurora HDR, after some effort you can achieve a somewhat acceptable image too.
kirk
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/08/3/LQ_871064.jpg
Image hosted by forum (871064) © kirkt [SHARE LINK]
Kirk
kirkt
Aug 16, 2017 12:36 |  #11
Here is a screenshot image from my files of the first round of testing I did with this image set, on the initial release of Aurora. Different problems, but problems nonetheless. The deghosting has improved though.
kirk
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/08/3/LQ_871081.jpg
Image hosted by forum (871081) © kirkt [SHARE LINK]
Kirk
Gaaaaa! DOH!! Oops!
Post edited over 6 years ago by Picture North Carolina. (2 edits in all)
Aug 16, 2017 14:21 |  #12
kirkt wrote in post #18429096 (external link)
kirk
Thank for the reply, Kirk. I won't be having fun because I see no reason to waste time on the app. To be honest, the challenge factor of your exposure set is mild compared to some things I produce. So if it won't work on yours, sure ain't 'gonna work on mine.
I'm wondering how luminosity masking would do. I recently abandoned Raya Pro and purchased the Benz product, but cannot test it myself because I have not had time to learn to use it. IMHO, the inability to process ghosting was the downfall of Oloneo. They tried, but just couldn't get it to work.
Oh, and as for your examples, add haloing. Somewhat substantial in my opinion.
Thanks for your time. It helped many of us save time by not wasting it on what appears to be a flawed app.
kirkt
Post edited over 6 years ago by kirkt. (2 edits in all)
Aug 16, 2017 15:15 as a reply to  @ Picture North Carolina's post |  #13
I would encourage folks who are interested to try it for themselves, really. I do not mean to discourage people outright, it just does not work for me, so I shared my experience with it.
As for luminosity masking, Aurora HDR actually has a zone system type luminosity mask engine built in - with a selection interface sort of like Nik SFX. You can use layers to composite your original source images back into the HDR result, and you can choose multiple "zones" to make a mask to do so. I have not really used the function.
Lumenzia is an evolving product that I have been using since it first came out. The author continues to refine and update the panel and it does an amazing amount of stuff, really really well. Not for everyone, for sure. Take a look at the tutorial videos - Greg does a good job at trying to demonstrate the various functions with in-depth video - you can access them in the help portion of the panel.
Sorry to hijack the thread on this.
kirk
Kirk
Gaaaaa! DOH!! Oops!
Aug 16, 2017 20:37 |  #14
kirkt wrote in post #18429454 (external link)
kirk
You didn't hijack it. The subject matter is Aurora and you stayed with it.
And I will agree. People should not take anything anybody says in any forum as gospel. They should try stuff for themselves. However, your comments were very useful. You identified the apps weak spots. When testing, outdoor landscape shots with movement will be the first thing tested. If it fails that, there will be no reason to continue testing.
And as an aside, agree about Lumenzia. I carefully researched LM masks. The one consistent comment was about Benz's incredible free training. That's why I purchased it.
Thanks for your help and invaluable input, Kirk. And thanks for the OP, MCAsan. Previous to this thread, I'm sure many were unfamiliar with Aurora. Probably because it was Mac-based. But with the new 2018 also being made available to Windows users, it is something people need to know about.
MCAsan
Joined Jun 2010
Aug 16, 2017 23:06 |  #15
While posting the images here may be interesting, wouldn't a better approach be to post them at https://www.facebook.c​om/groups/macphunphoto​graphy/ (external link) where Alex (Macphun COO) and his staff can examine them move towards a solution? I doubt we can solve the problem here.
4,813 views & 1 like for this thread, 5 members have posted to it and it is followed by 3 members.
913 guests, 119 members online
