Thread started 06 Oct 2017 (Friday) 20:58
Spot metering with different lighting on subject's face
southwestform
Joined Sep 2014
Oct 06, 2017 20:58 |  #1
Using a 5DM3 in Spot Metering mode and shooting a portrait of a fair skinned person in uneven lighting.
As I use the Spot Meter on different portions of the subject’s face, the meter changes based on the different lighting that hits the subject. I understand that this can be a creative decision, though generally, how do you determine where the meter should be on the subjects face when some portions will be darker and some lighter based on the different lighting? How do you determine which area should be within the midtone area and which should be within the highlight area? shadow? etc.
Thanks.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Oct 06, 2017 21:35 |  #2
Whatever you point it at, the meter is going to think it's seeing a midtone RGB 128 gray (more or less). So point it at whatever you want to be a midtone.
Run some test shots until you get used to it.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Oct 06, 2017 22:18 |  #3
southwestform wrote in post #18467546 (external link)
It is a creative decision, end of. You need to know what kind of image you want and then meter/set the camera accordingly. We can't tell you which area you should meter off because we have no idea (and neither does you camera) of what style of portrait you are taking and what elements are important to you.
Ultimately if you can't get the shot you want with the light that is available you need to move the subject to a location with better light, shoot at a different time or change the light by using reflectors and artificial lights (flash/strobes).
Dan Marchant
davesrose
Title Fairy still hasn't visited me!
Oct 06, 2017 22:32 |  #4
Evaluative metering is a pretty sophisticated form of metering that takes your AF point and color weighting into account. I bring it up, because I think it can be an easier metering mode (and is pretty good with the 5D3). Though it can be "tricked" into not knowing what subject you want if you have a scene that's overly bright, dark, or back-lit. I used to do more spot metering (back when I had the 5Dc), but these days I do more evaluative (for some scenes I'll switch modes or have specific EC values). If the scene is evenly lit, fair skinned people will be exposed properly. For African Americans, I've found I might need to EC +1.
If you do want to learn spot metering, directly metering fair skin is too bright: usual rule of thumb is to dial down a stop. Though when I'm really analytical with spot metering, I'll take in the whole scene (take in values of bright, mid-tones, and darker tones...and then figure the best compromise). I think it can also initially be challenging to figure out how a real world color scene might look as reflective black and white. Certain colors and saturations might actual be darker then what you'd think.
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
Wilt
Post edited over 6 years ago by Wilt.
Oct 07, 2017 01:42 |  #5
As pointed out, reflected light metering of the face largely amounts to 'subjective goal of the photographer'. The Caucasian face might be nicely tanned (after Spring skiing or summer surfing) to match the tonality of 18% gray card, or it might be about +1EV brighter than gray card during the deepest dark of Winter. So whether you expose for the shadows, or your expose for the highlights depends upon whether you are shooting color neg, or you are shooting digital or color transparency, or merely trying to make the photo suit a particular mood (or even the lighting falling on the face...contrasty lighting vs. low contrast lighting might entail different approaches.
wallstreetoneil
Gallery: 14 photos
Joined Nov 2014
Post edited over 6 years ago by wallstreetoneil.
Oct 07, 2017 05:06 |  #6
Read and absorb all the comments above but here is a specific strategy:
1) pick the brightest spot on the face, i.e. the highlight, that you want to be the highlight, and set the exposure meter, while spot metering this spot, to be a highlight - i.e. 'about' +1 1/2 to +2 EV above midtone
2) you can do the same as above, but with the darkest / shadow on the face, that you want to be a shadow, i.e. -1 1/2 to -2 EV below midtone
This is all an artistic choice as mentioned above - but that is how to spot meter
As a wedding photog, as an example, you can spot meter a white dress - and set the exposure with this being your white, with 1/3 to 1/2 stop protection so that it doesn't blow out - at around +2 1/2 EV (basically the strategy mentioned above but picking the wedding dress as white not the face highlight)
Another way to do all of this, and to show you why - it really is an artistic choice, is to put your camera into liveview mode and just set your exposure how you, the photog, want it to look - i.e. you aren't metering anything - you are choosing your final image in its entirety - once you see the image you want, note the settings and turn off liveview and shoot away
Hockey and wedding photographer. Favourite camera / lens combos: a 1DX II with a Tamron 45 1.8 VC, an A7Rii with a Canon 24-70F2.8L II, and a 5DSR with a Tamron 85 1.8 VC. Every lens I own I strongly recommend [Canon (35Lii, 100L Macro, 24-70F2.8ii, 70-200F2.8ii, 100-400Lii), Tamron (45 1.8, 85 1.8), Sigma 24-105]. If there are better lenses out there let me know because I haven't found them.
John ­ from ­ PA
Joined May 2003
Oct 07, 2017 05:36 |  #7
In the "old" days, and when something like an 85mm was used for portraiture, we used to meter off the back of the photographer's hand. And generally speaking we didn't have tools like Photoshop to tweak things later.
apersson850
Gallery: 35 photos
Oct 07, 2017 05:53 |  #8
The 5D models don't have the multi-spot metering from the 1D-series, as far as I know. Otherwise that's handy.
Anders
PhotosGuy
Joined Feb 2004
Oct 07, 2017 08:18 |  #9
John from PA wrote in post #18467702 (external link)
Just to "pick a nit", did you know that the palm of your hand doesn't tan? Which is why I use it here: Need an exposure crutch?
Alveric
Gallery: 38 photos
Oct 07, 2017 13:38 |  #10
'Tis been discussed before. See here: https://photography-on-the.net …showthread.php?​p=18424396
John ­ from ­ PA
Joined May 2003
Post edited over 6 years ago by John from PA. (2 edits in all)
Oct 09, 2017 07:16 |  #11
PhotosGuy wrote in post #18467751 (external link)
That is because the palm actually has a relatively thick layer of dead skin that prevents most UV light from reaching the appropriate cells that produce melanin which causes tanning. For the same reason, you can also use the bottom of your foot but I won't since that is not accomplished gracefully at my age!
Almost anywhere you find discussion of the hand technique, the process involves more or less a calibration process of comparing the hand to a gray card and establishing the difference which is then noted moving forward. All the techniques of years ago are just guidelines but in film days would bail one out when you had a dead meter or a fully manual camera.
One also has to watch out when using a gray card or you could miss by a 1/2 stop...see https://www.adorama.co​m/catalog.tpl?op=artic​le_050503 (external link).
apersson850
Gallery: 35 photos
Oct 09, 2017 08:12 |  #12
John from PA wrote in post #18468901 (external link)
For the same reason, you can also use the bottom of your foot...
Depends upon how fequently you wash them... :-P
Anders
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Oct 09, 2017 08:24 |  #13
Now that is real chimping because you would have to be one to do that.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2017/10/2/LQ_880093.jpg
Image hosted by forum (880093) © digital paradise [SHARE LINK]
Image Editing OK
RDKirk
Adorama says I'm "packed."
Joined May 2004
Oct 09, 2017 08:27 |  #14
Generally speaking, do not add exposure images of African-Americans. The exception would be extremely dark-skinned persons in contrasty lighting when you want shadow detail. Otherwise, expose normally and control contrast through lighting.
Wilt
Oct 09, 2017 13:27 |  #15
Yet OTOH, the palm is not pigmented even in dark-skinned races! which is why the palm is the universal reference of +1EV (vs. the 18% gray card)
16,916 views & 3 likes for this thread, 11 members have posted to it and it is followed by 5 members.
561 guests, 142 members online
