Thread started 13 Oct 2017 (Friday) 15:38
Slide - Inator Contraption... DIY bulk slide scanning...
embdude
Oct 13, 2017 15:38 |  #1
IMAGE: https://farm2.staticflickr.com/1556/26440284781_bf45d840f2_b.jpg
IMAGE LINK: https://www.flickr.com …781/in/datepost​ed-public/  (external link)
Contraption (external link) by C Canon (external link) on Flickr
My digital slide-inator
https://www.flickr.com​/photos/97603721@N00/2​6440284781/in/datepost​ed-public/
https://www.flickr.com …/album-72157667415136740/ (external link)
My goal: Scan thousands of slides quickly and maintain a decent level of quality.
Basic Components:
Canon 5DII (26x34 sensor)
Fuji 105mm enlarger lens
Kodak carousel projector
Additional components:
Opaque white plastic (placed just after the last glass element in the projector)
EF->Leica R adapter
Leitz Bellows R
Leica R -> L39 adapter
Wood
Hardware including washers as shims
Now that it is all together I need to tether it to laptop and fine tune focus and exposure settings. Initial results are promising...
-Chris
NEW: Photo Blog (external link)/ My Classic Cameras (external link) / Toys: Gear Sig...
Canon PDF's for EOS Digital Cameras (external link)
Free Photo Stuff Blog (external link)
embdude
Oct 13, 2017 15:50 |  #2
IMAGE: https://farm9.staticflickr.com/8526/28831871184_ec961e2a0a_b.jpg
IMAGE LINK: https://www.flickr.com …/album-72157667415136740/  (external link)
SLIDE-IN-ATOR notes: (external link) by C Canon (external link) on Flickr
Still refining my setup for copying my slides with a Canon 5DII
I misplaced my written notes so I will try to keep them here instead...
All advice and suggestions are appreciated =)
TBD: ISO, Jpeg settings...
CAMERA:
Canon 5D MkII
Best digital camera I have.
AWB seems to work fine
It is possible higher ISO settings pull more details out of shadows... more testing is needed to solve this...
Av (aperture priority) mode is used since the camera cannot control the lens iris. This way the camera selects the shutter speed automatically... 1/50 is common...
I sometimes re shoot with an adjustment to exposure compensation of +/- 1 before moving on to the next slide
JPG is preferred since the majority of the slides wont need further processing nor do they rate it.
JPG Settings: TBD...
For the best slides perhaps RAW would be better to get a fuller dynamic range...
SOFTWARE:
Canon EOS Utility
To tether the camera to my MacBook Pro.
Focusing can be done on the computer screen far more accurately than I can do it looking through the cameras prism viewfinder.
PROJECTOR:
Kodak Ektagraphic III
Replaced the original 4200 with an Ektagraphic III which has a brighter bulb, this helps with shadow details.
Like the later model Kodak Carousel projectors little to no heat reaches the slide so it retains a flat shape.
Older Kodak models generated enough heat to "pop" the slide curving it slightly. ( In fact earlier models came with lenses which took this curve into account and corrected for it.)
LENS:
Fuji Fujinon-EP 105mm 5.6 Enlarging Lens @ f8
f5.6 is not as sharp as f8 for the small details. f11 adds noise, probably from the back guts of the projector which are covered by a white piece of plastic...
This piece of plastic is from the local TAP plastics shop. I used the thinnest piece that was completely opaque, and had no visible grain or texture in it....
The 105mm lens is the best I have found for 1:1 copying at this distance. 75mm was too short and 135mm too long.
BELLOWS:
Leica R Bellows
A large and rugged bellows system it has the tripod mount on an adjustable rail so it can be refocused without adjusting the actual bellows extension.
A M39 --> Leica R adapter on the front to mount the enlarger lens, and a Leica R to EOS mount on the back for the 5DII
-Chris
embdude
Oct 13, 2017 15:51 |  #3
Not much progress to report.... Life has really gotten in the way of this project.... Hopefully I will be able to pick it back up in Nov 2017...
I did pick up a new enlarger lens a Schneider 80/4 Componon-S (latest version)... I will test it out to see if it covers ok at 1:1...
It has an amazing reputation so perhaps it will replace the fujinon EP 105 (mid 1980's) I currently have set up.... My initial feeling is that I wont see a deference between the 2 lenses but I might as well try...
-Chris
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 13, 2017 15:55 |  #4
Wow, what a cool idea!
Keep us posted.
CDS' HOT LINKS
2,095 views & 4 likes for this thread, 2 members have posted to it and it is followed by 2 members.
1346 guests, 136 members online
