Thread started 22 Oct 2017 (Sunday) 08:15
Camera Crash (5D3) What happened?
WAF
Oct 22, 2017 08:15 |  #1
Yesterday photographing a wedding the bride and groom were beginning their walk down the aisle. My Canon 5d Mark 3 "froze-up". It kept saying busy in the viewfinder and the back screen was like noise from a 1970's TV screen with no reception. I turned it off but it stayed "on". I dropped the battery out and put it back it and this corrected the issue for the night. In your experience / opinion, what happened? :rolleyes:
Adrian ~ Canon 30D, Canon Mark3, Canon 5D MarkII, Canon 5D MarkIII, Canon 7D, Canon:70-200mm/f2.8, 85mm/1.2, 50mm/1.4, Canon 14mm Fisheye, Canon 16-35mm f2.8L, Canon 24-70mm f/2.8, USM, 1.4X, 2.0X , Quantum T5d-R flashes.http://www.adrianfreem​an.com (external link)
Bassat
"I am still in my underwear."
Joined Oct 2015
Oct 22, 2017 08:24 |  #2
My first move would be to re-flash the firmware. Hope it goes away.
Bassat
Joined Oct 2015
Oct 22, 2017 08:27 |  #3
Canon made a 14mm fisheye? 15mm, perhaps?
John ­ from ­ PA
Joined May 2003
Oct 22, 2017 08:44 |  #4
WAF wrote in post #18478181 (external link)
Were you using a grip, and if so what brand?
There is a fair history of people with similar issues that commonly involves use of a grip, often a 3rd party but some instances of the Canon grip.
WAF
Oct 22, 2017 09:13 as a reply to  @ John from PA's post |  #5
No grip and no accessories except canon 580 EXII flash. Thanks for asking.
WAF
Oct 22, 2017 14:44 as a reply to  @ Bassat's post |  #6
Done. Thanks for the suggestions.
ejenner
Gallery: 98 photos
Joined Nov 2011
Post edited over 6 years ago by ejenner. (2 edits in all)
Oct 24, 2017 21:14 |  #7
I had this (not even switching off), BUT, I can't remember whether I had magic lantern installed or not. Probably, but in any case it sounds very similar to what can happen when ML goes 'wrong'. Since ML is just a additional firmware, then I would suspect that this was a firmware issue/bug/glitch. It may not be repeatable and may be a very specific sequence of things you did + settings.
Usually (well always for me over the last 6+ years) when this happens there are no lasting effects. I will always try to repeat what I did to help debug ML, but often I cannot and I never encounter the same problem.
Hope this helps alleviate a concern, and hopefully it was a one-off that won't reappear.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
4,339 views & 0 likes for this thread, 4 members have posted to it.
1502 guests, 130 members online
