I'm on my second Canon 50mm. Both have required ~-20 MFA on three different 5D bodies. But I like how it worked for this photo, with -19 MFA.
Nov 11, 2017 21:28 | #1 I'm on my second Canon 50mm. Both have required ~-20 MFA on three different 5D bodies. But I like how it worked for this photo, with -19 MFA. Image hosted by forum (885462) © KatManDEW [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Nov 11, 2017 23:53 | #2 Hmmm, are you sure? Looks to me like you are focused in front of her. Hard to tell exactly but the camera in front of her seems pretty sharp and looking at the flags on the side of the barrel it seems the ones roughly in the same plane as the camera lens are also in focus. My flickr
Nov 13, 2017 19:04 | #3 FTb wrote in post #18494415 Hmmm, are you sure? Looks to me like you are focused in front of her. Hard to tell exactly but the camera in front of her seems pretty sharp and looking at the flags on the side of the barrel it seems the ones roughly in the same plane as the camera lens are also in focus. Since you're shooting pointed slightly down, the plane of focus would be tilted back a bit from purely vertical towards her. But I'd be willing to bet she is at the back of your focus plane and maybe slightly out of it. I've got the same lens and love it, but mine doesn't require any mfa. I see what you are saying. I took several comparison photos with -19 and 0 MFA and I am going to inspect them.
FTb Senior Member More info Post edited over 6 years ago by FTb. (3 edits in all) | I've found a couple of things that work for me to adjust mfa. I ALWAYS use a tripod to eliminate camera shake as a variable. My flickr
kf095 Out buying Wheaties More info | Nov 13, 2017 21:22 | #5 I gave up with 50L on 5D MKII and MFA. It was spot on with 5Dc. M-E and ME blog
Nov 15, 2017 02:01 | #7 Nice You don't take a photograph, you make it...Ansel Adams
Nov 15, 2017 03:09 | #8 f/1,2L is difficult to do the focus and recompose. Canon R3 | RP | 7D2+grip | EF 70-200mm f/2,8L IS II | EF 135mm f/2L | EF 50mm f/1,2L | RF 100mm f/2,8L | Tamron 24-70mm f/2,8 VC G2 | Tamron 17-35mm f/2,8-4 Di OSD | ZE 2/100mm | ZF 2/35mm | ZF 1,4/85mm | ZF 2/135mm | CV 1,4/58mm Nokton | Micro-Nikkor 60mm f/2,8D | DC-Nikkor 105mm f/2D | Micro-Nikkor 200mm f/4D |
Nov 15, 2017 07:44 | #9 I had to use focus compensation on my camera bodies. But I never had a problem missing focus with the 50 1.2 in fact it is my go to over the 85mm f1.2 when the subject is likely to move and I want a shallow DoF. I go to the 50 because it focusses faster than the 85. I try to make art by pushing buttons
| Latest registered member is semonsters 1431 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
