Is there a specific way to do it in LR. I click "remove chromatic aberration", but I don't see a difference. I see there is a little Doppler but how do you do it with that. I have the famous 85mm 1.8, which is known to be the worst for this.
Nov 14, 2017 09:35 | #1 Is there a specific way to do it in LR. I click "remove chromatic aberration", but I don't see a difference. I see there is a little Doppler but how do you do it with that. I have the famous 85mm 1.8, which is known to be the worst for this. Anita W.
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 14, 2017 11:33 | #2 Personally if you have a lot of the purple/green fringes I would try to avoid using the global corrections. The global correction is going to really mangle any areas in the image that are close in colour to the range selected if you need anything but the absolute minimal level.
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Nov 15, 2017 11:53 | #3 I see by your profile that you have a 7D which I believe can do lens specific corrections for chromatic aberration "in camera". Have you enabled it to see if the correction is sufficient?
Nov 15, 2017 12:23 | #4 John from PA wrote in post #18497138 I see by your profile that you have a 7D which I believe can do lens specific corrections for chromatic aberration "in camera". Have you enabled it to see if the correction is sufficient? i will check tonight. I do have the 7D Anita W.
ejenner Goldmember More info Post edited over 6 years ago by ejenner. | Nov 16, 2017 21:14 | #5 I'm guessing your issue is with green/purple fringing. Does LR5 not have a separate correction for that? If not, there might be a preset/action somewhere or whatever the LR equivalent is. The de-fringing on ACR with CS6 usually does a good global job, especially if you tune the color. Edward Jenner
Stiga Cream of the Crop More info | Nov 21, 2017 08:11 | #6 Download the FREE DxO Optics Pro - see this thread; https://photography-on-the.net …/showthread.php?t=1488607 Martin
| Latest registered member is semonsters 1677 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
