Thread started 17 Nov 2017 (Friday) 19:08
Reliability of Evolv 200
silvermesa1
Joined Aug 2013
Post edited over 5 years ago by silvermesa1.
Nov 17, 2017 19:08 |  #1
It seems most people like the evolv 200 yet there seems to be some occasional challenges as well. Do you think Godox addresses these issues as they are found,or will it be version 2 before corrections get implemented?
Those of you that have purchased them, would you buy them again?
A few challenges I read about:
1) Overheating
2)bulb head not working unless pressure is put against it
3) LCD screen not easy to read outdoors
Jarvis ­ Creative ­ Studios
Gallery: 28 photos
Joined Aug 2013
Nov 17, 2017 19:32 |  #2
Never had any of these issues. Only issue I ran into was the LED head not working, but a firmware update fixed that. Yes I would buy them again. In fact, about 2 weeks after I got my first I bought another one.
I have been using only Godox lighting since moving to Sony, and couldn't be happier. It's SO much better than the Yongnuo 600EX-RTs I used to use. There are only two things I would change about the lights I have, and neither of these issues are on the AD200. 1. I wish the flashes had quick attach / releases instead of screw mounts. 2. I wish you could turn off the flashing red light when the flashes are in wireless slave mode (maybe you can, but I have gone through the menus a ton and can't find it).
WEBSITE (external link)
Sony ZV-1 || Sony a7RIV || Sony a9 || Sony a1 || Sony FE 20mm f1.8 G || Sony FE 24-70 f2.8 GM || Sony FE 50mm f1.2 GM || Sony FE 90mm f2.8 Macro G OSS || Sony FE 135mm f1.8 GM || Sony FE 200-600 f5.6-6.3 G OSS || Godox speedlights and strobes
Osa713
Gallery: 48 photos
Joined Jun 2011
Nov 17, 2017 20:17 |  #3
Didn't have these issues with mine either, and yes I would buy the unit again if I had a specific use for it. The only reason I moved on was to get the xplor 600.
Is the LCD easy to read outdoors in the full sun? NO but its not impossible.
LIGHT>LENS>BODY
Big_Tyke
Post edited over 5 years ago by Big_Tyke.
Nov 18, 2017 05:58 |  #4
silvermesa1 wrote in post #18498835 (external link)
1) Overheating
I have mine for two months now and have been using it on my outdoor photo shoots a lot and don't have any of the issues above. Also, mine came with the current firmware so I didn't have to do any updates.
My second unit is coming soon and will be using it with the Godox AD-B2 adapter, this way I will have more flexibility. Although, I have never need it yet, I do have a spare bulb and battery, just in case.
The display panel is hard to read under bright sunlight, Yes, but for me it's a non issue, since I am making adjustments on either the trigger or camera. It would be a lot of work and wasted time to read the panel when it's up high on stand.
I trigger this with the Godox X1T, works great but often times my forehead touches the buttons and the setting changes, which many people have complain thru the web, so I got the new Xpro trigger, which is great btw and very happy with it so far for its ease of use. So, is Godox listening, maybe!
bobbyz
Nov 18, 2017 09:24 |  #5
Where did you read about these problems? Besides LCD being harder to read outdoors, we haven't seen anything else mentioned here on POTN. For the price, what other better option is out there? Could it be better, yes but that is with all the products.
Fuji XT-1, 18-55mm
silvermesa1
Joined Aug 2013
Nov 18, 2017 11:08 |  #6
bobbyz wrote in post #18499066 (external link)
It took me a bit to find where I was looking at but here are two examples. Very well could be a a small problem with more happy customers than not.
1) https://www.youtube.co​m/watch?v=Llw3zDF0AL8 (external link)
(Look at the video 11:36 to 13:55 and also look in the comments section below the video. Several people chime in.)
2) https://www.dpreview.c​om/forums/thread/41614​08 (external link)
bobbyz
Nov 18, 2017 13:30 |  #7
Thanks. The youtube poster said smoking, that means bigger problems. I would have talked with Adorama. I haven't used my AD200 much as I already have AD600s and they have been running fine so far.
Fuji XT-1, 18-55mm
simonbarker
Nov 18, 2017 14:54 |  #8
There isn't a brand out there that has a zero failure rate and given how many AD200/AD600 units are out there if they had a horrific design flaw there would be a lot more reports by now.
If you're doing critical work you need to have back up units and that is true for every brand, there's unlikely to be any fixes put out for current models, they'll just get replaced by new models rather than have expensive fixes unless it falls into the seriously dangerous design flaw category.
wolverinesr1
Joined May 2004
Nov 20, 2017 05:40 |  #9
I have two of the evolv 200, and have used them in about six indoor photo shoots, and they have been very reliable. I shoot indoors in a somewhat small kitchen so they have never needed to be over 1/2 power so overheating has never been an issue, and recycle times are quick.
I have heard from many that the lcd is hard to see outdoors, but that would be no problem for me, because I use the X Pro C for all my settings. I have one ad 600, two evolv 200, and two V 860 flashpoint equivalents. I can control all of them with the X Pro C, and it allows HSS,TTL, and second curtain sync.
They all have been reliable, love this system!!
Jeff
Canon 5D iii, Sony A-7iii, Canon 24-70 2.8L, Canon 70-200 F4L, Canon 100-400L
Sigma 150-500 DG OS f 5-6.3
4,991 views & 2 likes for this thread, 7 members have posted to it and it is followed by 4 members.
1322 guests, 169 members online
