Choderboy wrote in post #18504987
That does seem like the problem Kris is referring to. Although it is described as a sensor issue, I experienced the problem with an EF50 1.4. I think the lens needed repair, problem occurred even stopped down to 2.8, but Kris's example photo matches what I saw. I called it colour bleed, not having heard the term blooming at the time.
It is due to a combination of lens and sensor problems. I have been doing more reading on lens design lately, but certainly not enough to sound intelligent, or competent, when really getting into the details. But my understanding is that virtually everything is a compromise with lens design. Yes, lenses can, and have, become more complex to deal with these issues but the result can often exacerbate one problem while fixing another.
Higher pixel densities means these problems become more and more noticeable AND prevalent. I beleive one of the reasons that article attributes blooming to compact cameras is due to not just to their lenses, but their cheapish sensor designs and higher pixel densities.
Just as with lenses, the design of the sensor microlens array becomes much more important with higher densities. So the design of the entire system from front element to sensel needs improvement to maintain perceived quality. Put the same 50mm lens on a 5DC rather than an 80D and I suspect there might be a vast difference in "IQ"
