I have an NEC MultiSync P221W display that I calibrate with an NEC SpectraView II sensor. Does anyone know how effective the SpectraView II will work in calibrating a new iMac 27 Retina display?
Thank you.
kitjv Member 238 posts Likes: 3 Joined Nov 2007 Location: Oregon USA More info | Nov 27, 2017 23:55 | #1 I have an NEC MultiSync P221W display that I calibrate with an NEC SpectraView II sensor. Does anyone know how effective the SpectraView II will work in calibrating a new iMac 27 Retina display?
digitalparadise Awaiting the title ferry... More info Post edited over 5 years ago by digital paradise. | Nov 28, 2017 19:57 | #2 No. Spectra was designed specifically for NEC so the software works with NEC only. I had to get an i1 Display Pro for my iMAC. My Spectra collects dust now. Image Editing OK
digitalparadise Awaiting the title ferry... More info | Nov 28, 2017 20:01 | #3 Don't want to lead you astray so I blew the dust off. I think the software I was using was called Spectravision. Image Editing OK
Nov 30, 2017 21:43 | #4 NEC confirmed that The SpectraView II sensor will only work properly with NEC displays. Also, the sensor will not work with 3rd-party software.
digitalparadise Awaiting the title ferry... More info | Dec 02, 2017 08:33 | #5 Yes I was pretty sure you couldn't. I may have called XRite myself but that was 4 years ago. Your sensor's name is different so I wanted to be sure my info was not accurate. Image Editing OK
| Latest registered member is semonsters 1040 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
